thought i had best come clean....
I don't drive a Clio.....the closest I've ever come to owning one is a Megane....
if you were to search my posts you will find i only post in response to questions regarding car audio, i don't claim to be an expert, but i would class myself as being almost competent
My car audio consists of;
Headunit----Becker Mexico Pro
front components----Infinity 'Kappa' 6 1/2"
rear components----Infinity 'Kappa' 6 1/2" (mounted in sealed boot enclosures)....
4 channel amp----JBL PX300.4
mono amp----JBL/CROWN BPX2200
subs----JBL GTi 12" MKii X2
the initial build before upgrades...
new mono amp fitted with original subs (JBL P1220e X2)
new subs fitted,(these subs require a mounting depth of 11", plus 3" for venting), as you can see the panels no longer fit, (but this will be sorted when its rebuilt later this year)......
here's a pic showing the dual power supply and 'parallel' bridged sub outputs....
current output is a tad under 3kw rms.....current dB reading ??? will guess at mid 130s....
please note; this system was built by me, for me....it wasn't built for SPL, it wasn't built for quality....it was designed and built to play with the hatch open, as well as whilst being driven, with a little adjustment of the fader control it performs both tasks quite well.....
it will play almost anything from ABBA to Cliff Richard, from Elektro through to Disco, 80s Funk to Bass Mekanik......
hope you don't mind me not owning a Clio, (at 6' 3" i probably wouldn't fit
