high 190's, and maybe 200 if you added a 182 manifold
On an otherwise standard engine block these cams have produced over 200 BHP.
These are only plans at the moment. .
well if you ditched the panel filter and went ITB's you would have circa 225-230.These are only plans at the moment. .
What would you estimate???
- Clio 172 cup
- ITG panel filter
- KTR 182 manifold
- KTR Decat
- Miltek Cat-back
- Schrick Billet Cams
- RSTuning Re-map
:S
450 bhp easy!
shrick cams are expensive, mine are catcams - much cheaper
- Clio 172 cup
- ITG panel filter
- KTR 182 manifold
- KTR Decat
- Miltek Cat-back
- RSTuning Re-map
:S
It's just a renault manifold mate
Sorry, I'm sure you knew that.
Is this plans, or have you fitted this?
Doing any of the work yourself.
My guess is between 194 and 202bhp. Hows that?
a KTR decat is also just a decat...
I dont get it lol
Sorry to hi-jack, what do you guys reckon my 172 should be putting out, the list!
Cat back powerflow sytem 2" with 2 straight through silencers
De-cat
RS tunner Group N map
ITG Pannel filter
was hoping for the 190hp figure, engine does feel great so one can hope lol :approve:
What do you reckon?
i aint even pushing 200 with,
gdi cam package, ie match inlets, remap and cams
decat
exhaust
itg max with 3 cafs
Thats gay, hoped to be putting down atleast 180hp... it aint easy making more power.. on with the matched inlets!
When, Where?Come to the Rolling Road Day and find out!
I had 233bhp (more now)
Fook me your motor must move! what sort of 0-60 times does that pull?
5k, thats k-tec turbo right there.. 250bhp "supposedly"
doing santa pod in 2 weeks, so i'll see then. 'should be mid 13's all going well'
5k +vat. but it's a turbo. loads of torque and broken gearboxes.
Mine's n/a, no lag, just goes like stink.
no idea what 0-60 is, 2 reasons why; traction and too busy changing gears
I thought the fastest na clio run 13.2's . I did a 14.5 with a slipping clutch this year and loads of wheelspin!5k +vat. but it's a turbo. loads of torque and broken gearboxes.
I dont think anyones cracked 13's with a F4R running a N/A set up of any discription never mind mid 13's ??
