LED Interior Group Buy....Poss
Car  White Sti Hatch
Been speaking to the person i got my lamps from as he is willing to create kits for a group buy if anyone would be intrested....
I have no prices as of yet as i need to know whats reqired for other cars other than the standard Mk3 witch is
3x 501 6LED Lamps
2x 36mm 6LED Feston
Would anyone be intrested in these for there car if so jot your name down with whats required for your car and ill try get this set up...
Anyone be intrested in this ??
Once its a Bit Darker out side ill get some pics of my car up !
if you can do the 172 (ph2) then i'd be interested
Well if you tell me the required lamps for Boot, glove Box and Front witch i think are all 36mm Festons ill start a list and once i have a few i will send it off and get prices
iv got 36mm festoons in my courtesy light and boot light. fit perfectly. dno about the glove box..
Well to get the prices i need to know the Type and Size of lamps needed for each car and also how many of each !
Im very interested on some for my 172 cup interior light glovebox light and boot light in white would be good any ideas on the price for the lot
As i said above mate i need to know the Size and Type of lamp and how many are needed before i can get a price for the kits
Right types of bulbs are as follows...
Rear Boot Light: - Festoon 39mm
Glovebox Light:- Festoon 39mm
Map light and Interior Light (172 only not cups!!) :- 501 fitment
Sidelights:- 501 fitment again I think (havent checked coz its a pian to get to them but from memory they are the same as interior and map lights)
Rear Number plate Light : - Ahvent checked yet...il do that in a moment.
Now most models of Ph2's should be exactly the saem for all the interior ones. Only difference might be the SIDELIGHTS.
Also its worth remebering that in a CUP you cannot fit a interior LED (where the map light goes) this is due to the Cups being wired slightly differently etc.
Rear number plate light is this type....
I need 3 39mm feson type bulbs for my cup 1 for the interior light 1 for the glovebox light and 1 for the boot iv just checked and there all the same bulbs so how much will these be cheers.
Im just trying to set it up for the Interior just to keep the amount of diffrent type bulbs that have to be used....
Yes it would be but there is a choice of colours. As for the price i will start another thread once i know what each car needs and once i have a few names i will contact the guy and see what he can do price wise
[FONT=arial,sans-serif]1. 3x501 6LED 2x6LED 36mm Festoons - Mk3 Dyn S
2. 2x8LED 39mm Festoons 1x501 6LED - Mk2 Ph2
3. 3x8LED 39mm Festoons - 172 Cup
Normal price (excluding p&p):
1. 9 pound
2. 6 pound
3. 6 pound
More than 5 kits on each 1., 2. and 3.:
1. 8.70 pound
2. 5.80 pound
3. 5.80 pound
More than 10 kits on each 1., 2. and 3.:
1. 8.40 pound
2. 5.50 pound
3. 5.50 pound
More than 20 kits on each 1., 2. and 3.:
1. 8.00 pound
2. 5.00 pound
3. 5.00 pound
Please note that all of the prices above are excluding the p&p. The p&p is depended on the final quantity that you purchase.
[/FONT]
Aye they did mate cheers....
So are people happy with those prices if so i will start another thread and get the names down
so how much for a 39mm bulb for my boot?
and maybe a rear number plate bulb
1. 9 pound
2. 6 pound
3. 6 pound
1. 8.70 pound
2. 5.80 pound
3. 5.80 pound
1. 8.40 pound
2. 5.50 pound
3. 5.50 pound
1. 8.00 pound
2. 5.00 pound
3. 5.00 pound
[/FONT]
Just a quick thing I noticed... On the PH2's there are 2 501 fitment led's. One for the map light and one for the Interior light.
Maybe it was how i worded it for you. Just wanted to let you know :)
Ah right was the way you put it in the other post ill get onto him and see how much the price changed for that then ill start a proper thread and see if anyone is actualy intrested at all
my car only has two 39mm festoons, interior and boot,
how much for two 39mm and a rear numberplate bulb???
Yeah apologies I was reading back through this thread and noticed.
Said it once ill say it again the buy will be for the Interior lamps only !
Echo... echo... ;)
Tey it the other way round dude... leds have a polarity. If your stuck to what I mean...
Take out the bulb and rotate it 180 degrees and it should work.
is that the cheapest you can get them when are you starting a thread be best to put the thread in the car parts for sale
yeah that does work cuz that happened with my blue led in my old old car
It will be the same for all the Festoon tyoe ones for you glove boxes too. It wont work one way but will work the other. I can't tell you which way round though im afraid... trial and error unfortuantely (only take 10 seconds!)
Right now im a bit busy to set it up but i will try my best to get everything sorted out and a thread started on friday !
