my clio with matched inlet graph
Car  E39 M5 & Corsa track
did a bit of work on the clio last night, people have always been saying the standard inlets are rubbish, very poor matching etc. so i took the liberty of finding a spare inlet and matching it, open it up to match the head etc...
to be honest i was impressed with the gain, but it matches what everyone else says.
i also added a new exhaust at the same time so i dont expect the gain to all be from the inlet!
as standard the car was:
166bhp 141lb ft
with matched inlet and cat back yozza sport system:
185bhp 156lb ft
how accurate is our rolling road, well we calibrate it every 3 months.
however one run to the other was a few hours apart, the proof of there being a gain is still there, did 3 runs with no difference rather that just one run on each set up.
I didnt believe the gains would be anywhere near what they were,
even if the power isnt 100% accurate it doesnt take away from there was a good power gain there, i say fair play chap
Same Dyno = Same Higher/Lower readings so the Difference should still be Pretty accurate
I've never denied it, Might try and get some bought and fitted when the Cambelt gets done, Maybe add some of those Hill Power Gaskets aswell for good measure
Could now bring competition on AWT to Bring th price of there Inlets down, £117.50 from Jam-Sport I believe,
Likely to place an Order at some point me thinks :)
well as can be seen above it works well with a ported inlet! i should have done a run with the exhaust and one with exhaust and inlet, but i didnt have time and i wanted to go to bed!
exhaust fits really well tho, makes a change from some of the systems we see thru our workshop!
we are developing a range of kits for the clio, i am looking at being a proper trader on here so as not to step on anyones toes....
Sounds promising... Shame your so far away from me as I would be more than willing to have developement/tests done on my car :)
Quite near me :)
What other services do you offer? Can you do matched inlets now or are they still under development?
i can do them now, i have an rs inlet being done as we speak.
what else do you want doing, anything from a basic service to ITB conversions or supercharger conversions etc...
the jamsport dyno was pretty spot on compared to another on my bro's c20xe corsa... broster, you know the one ;)
What's the difference between these inlets and AWT's? or is it just the suspicious result lol :S
^^ none ?
Matched is matched i'm guessing
Nice results !
Before a cat , after no cat ?
I can sell you some water. It'll make your penis grow to 20'' AND can also be used to float your boat!!
100 quid to you + vat - deal ??
Guys, im booked in to have my Clio 172 FF(52 plate) inlets matched.
Jamsport are doing a before and after run.
I have ITG panel filter and Ktec exhaust from CAT back. (with no centre silencer)
Power run will be done on this setup, then with matched inlets. This is being done in two weeks so results up soon :) should sort out whats what :)
Good Stuff be good to see what these will make on a Normal Unmapped car :)
Angelworks, Jamsport, AP-Developments and GDI
Take your pick
