All the same then at the end of the day
Really?
Ive seen some shocking examples....
Really?
Porting heads/inlets etc is an art, we have seen some heads which look good but perform shockingly! same with inlets on some cars we have thru the doors for rebuilds the ports are all different shapes etc, not as easy as people make out.
Guys, im booked in to have my Clio 172 FF(52 plate) inlets matched.
Jamsport are doing a before and after run.
I have ITG panel filter and Ktec exhaust from CAT back. (with no centre silencer)
Power run will be done on this setup, then with matched inlets. This is being done in two weeks so results up soonshould sort out whats what
booked in on the 13th so will post results up on the monday after.
Sean, it'd be interesting to know if your before inlets have the RS stamp.
Sure all Cups had RS inlets as standard?
Hi all, the results are in and the work is done.
So now the important bit you've all been waiting for.
Before run:
171bhp @ 6227Rpm
156lbft @ 4995
That is with Ktec stealth exhaust and ITG panel filter. Car recently serviced 1000miles ago.
After run:
179bhp @ 6105Rpm
163lbft @ 5056Prm
With the mathced inlets done and same mods as above.
So an increase of 8bhp and 8lbft of torque. How does it drive? well much better actually, small differences but overall car feels more punchy, picks up when overtaking a bit better. Gets to the tops speeds a little quicker than before. Pulls better through the revs in the higer gears. Overall very happy with such a simple mod. Didnt expect miracles and i didnt get any but worth while none the less.
Supposably the 182 all have the "RS" lower manifold which is good enough / alot better than the 172 lower manifolds. Not really worthwhile doing the 182 manifold matching , brings almost no improvements so i've heard/read
