Shorter exhaust pipe
Should i leave it as it is -
http://i395.photobucket.com/albums/pp31/GTBen/IMG_1218.jpg
Or get it chopped a little shorter like below
Comments and opinions.
If a mod could set up a poll for me with the two options please.
thanks
Shorter BUT it will make it more noisey in the cabin I should think.
f**k that leave it long,
looks slagish at the moment all bronze and long.
these fools dont understand linge!!!!
I'd leave it as it is, make the car look more agressive for some reason.
Its the ONP Group N isnt it?
Could you not shorten,raise then pop into power flow or some thing for a nice tip? I know there a hardcore system but yozza managed to make there's look smart enough
Doesnt need another tip. Its cup racer style..... Think its the system that needs shortening, not the tail pipe according to kev?
+1
the pipework further up needs shortning, not the tail pipe.
or slash cut the tail pipe??
Take it to powerflow in crewe mate, they will remove the tail pipe, shorten it then reweld it back on:)
Don't have it cut you want it to say OMP!!
I wouldnt cost more than £40 either, they removed my center section and replaced it with a straight through pipe and fitted it to the car for £103:cool:
Get it done Ben;)
I recon you can pinch 10mm off the centre section!!!
I had to cut off 10mm from centre section my Magnex fitted to the cup a few years ago!!! Hacksaw ftw!!!
Fitted 100% better then!!! Later banging on the rear beam!!
How a yozza looks..
Want it cut into the bumper ideally... i might do it one day
