182
want to take mine out but did a search for the guide and couldn't find it?
how do i go about it
baically its a device which helps the car pass stupid EU drive by noise regs etc, free's up a little more induction snort once vanquished
the cliotrophy link/guide that curley posted is step by step and very useful.
if you are thinking of removing the acoustic valve, i would give this a good read!
Also, Print it out and read as your going along if needs be
surely the acoustic valve was not connected to the viper anyway?
that bay could do with a bit of a tidy up
WIP dude(work in progress!) house is caining the car funds at the mo
no but it was connected to the standard airbox at first... then removed just before fitting the viper and didnt notice any sound difference.
Just rip it all out and get an Uprated CAF............If I can do it anyone can LOL
or if you have a wireless laptop, take it outside. i dont have a printer![]()
It used to as I had a CAF Trumpet in the lower grill but I swapped it back to an uncut one this weekend and am now trying to decide where to run them to..... Ph2 Airbox has 2 feess running to it.
Where can i get the ducting like that from?
plagerism ftw!
A short guide
* Remove (entirely) the air box, disconnecting both air feeds (one to the right and one directly under). Air box is held in place by two screws and jublie clips
* Jack the car up under front left, ensure you use a axle stand or similar
* Remove wheel, place neatly elsewhere
* Remove the underside arch-liner, fastened by a few torque screws and some fat looking plastic plugs (these just pull out with a tug)
* Watch for the small ribbed cable (battery acid overflow pipe) as its connected to the arch liner. Let this dangle somewhere.
* You will now have exposed the underside of your front bumper, note the bracket holding both your horn and the acoustic valve.
* Try to unclip as many of the wiring looms to both the horn and the valve, let these looms dangle somewhere
* Undo the bolt holding the bracket in place
* Tuck the horn assembly somewhere out of the way
* Remove the small air feed, no 1, simply turn it to unclip
* Remove accoustic valve by pulling it downwards and out of the wheel arch, if you meet resistance check looms are disconnected and path is clear
* You should be left with a large gap / hole
* Accoustic valve will be connected to a thin black tube, remove as much of the connecting bits, leaving just the tube.
This must be blocked off (or you will idle above 1000rpm) with a screw / bung similar
Tape the screw in place
* Remount the horn, reconnect horn wiring loom to horn, screw bracket back into place
* Tape up all looms and cover ends with tape
* Tape blocked pipe somewhere
* Once the valve is removed make any modifications you wish, i.e place your airfeeds etc
* Reconnect the battery overflow pipe to the grilled bottom of the arch liner
* Replace arch liner, fix with plugs and screws
* Put wheel back on, ensure wheel is flush to brake when placing nuts or you will mark your wheels
* Lower car
* Connect new air feeds to air box, replace air box, ensure jubile clips are tight
* Job done, admire your work.
Start car, check horn, leave to idle for 2mins ish - idle @ 800rpm ish?
Oh... ive removed it now... all ive heard is its not needed
