Honda CRV
				My daughter recently had her 2004 clio 182 cup serviced. Renault dealer in Leicester quoted her £1500 for new cat and new driveshaft due to engine management light being on and ABS lighting intermittently.
Quotes from dealer :
"Can't change the reluctor (ABS) ring on a 182, needs a new driveshaft - £500 fitted"
"Tester showing catalytic converter functional fault, this combined with middle exhaust section rattle suggests the catalytic converter has broken up - replacement cat £1000 fitted"
Having read loads of threads on here:
a) sounds as though middle section exhaust rattle is common.
b) sounds like there may be an issue with lambda sensor and not cat.
c) Have found broken reluctor ring on offside.
Just been down to buy a reluctor(ABS) ring from local Renault dealer in Cannock who quoted me £211 for complete drivesahaft saying they "don't recommend just changing the ring as this can set all the airbags off"
Is this more b****cks or should I be taking a lot of notice of all these comments?
Seems to me that dealers are finding they can't sell cars and so are trying to make money out of servicing or repairs. All the above seems like a rip off to me, I can buy an ABS ring for £30, lambda sensor for £100, and a generic cat for about £250.
Any comments would be helpful as I am new to Clio's.
As a last question, what is the grease that they use to pack the cv joint with inside ther gaiter? Is it anything special or will any high melting point graphite grease do?
Thanks for looking.
Thanks for looking.
