PH1 172 + 182 Gearbox
Waitey
Car  M3 Touring, AC Cobra
Any way i can get a speedo reading from the abs sensor at the back. Will it work with the dash?
There must be a way of fitting the speedo sensor from the old box in the 182 box. Im not sure if a 182box just has a blanking plug fitted??
The sensor hole is the wrong size and theres no internal gearing to run the sensor.
The 182 and PH-1 172 run different gear box housings... not compatible IIRC!!
My PH-1 box and 182 box are next to each other and they are very similar.
What i want to know is can i get a PH-1 to get the speedo signal off the rear ABS ring?
Unless the rings have the same amount of teeth, I doubt it. Ditch the ABS and use them as wheel speed sensors?
No where has a good one. I was sold a 182 box as a PH-1 172 box so i'm stuck with that too.
