Waitey ClioSport Club Member Car M3 Touring, AC Cobra Mar 26, 2009 #1 Any way i can get a speedo reading from the abs sensor at the back. Will it work with the dash?
davebem Car Lots of Alfas Mar 26, 2009 #2 There must be a way of fitting the speedo sensor from the old box in the 182 box. Im not sure if a 182box just has a blanking plug fitted??
Waitey ClioSport Club Member Car M3 Touring, AC Cobra Mar 26, 2009 #3 The sensor hole is the wrong size and theres no internal gearing to run the sensor.
G Gray Car M3 Touring Mar 26, 2009 #4 The 182 and PH-1 172 run different gear box housings... not compatible IIRC!!
Waitey ClioSport Club Member Car M3 Touring, AC Cobra Mar 27, 2009 #5 Gray said: The 182 and PH-1 172 run different gear box housings... not compatible IIRC!! Click to expand... My PH-1 box and 182 box are next to each other and they are very similar. What i want to know is can i get a PH-1 to get the speedo signal off the rear ABS ring?
M mini-valver Mar 27, 2009 #6 Unless the rings have the same amount of teeth, I doubt it. Ditch the ABS and use them as wheel speed sensors?
Waitey ClioSport Club Member Car M3 Touring, AC Cobra Mar 27, 2009 #8 No where has a good one. I was sold a 182 box as a PH-1 172 box so i'm stuck with that too.
