PH1 172 + 182 Gearbox
Waitey
  Alpina D3, AC Cobra
Any way i can get a speedo reading from the abs sensor at the back. Will it work with the dash?
  Lots of Alfas
There must be a way of fitting the speedo sensor from the old box in the 182 box. Im not sure if a 182box just has a blanking plug fitted??
Waitey
  Alpina D3, AC Cobra
The sensor hole is the wrong size and theres no internal gearing to run the sensor.
Waitey
  Alpina D3, AC Cobra
The 182 and PH-1 172 run different gear box housings... not compatible IIRC!!
My PH-1 box and 182 box are next to each other and they are very similar.
What i want to know is can i get a PH-1 to get the speedo signal off the rear ABS ring?
M
mini-valver
Unless the rings have the same amount of teeth, I doubt it. Ditch the ABS and use them as wheel speed sensors?
Waitey
  Alpina D3, AC Cobra
No where has a good one. I was sold a 182 box as a PH-1 172 box so i'm stuck with that too.
