Passenger side... theres no f**king room with the fuse box there! got the new bulb in the socket but cant twist the thing back on/?? do i clip the metal clips in first or after then twist? WTF! pissing me right off!
The wire clip has to go on first before the black plastic starter btw, and you then have to put the starter on the bulb before plugging the wire back into it, which I found out after a loooongggggg time f**king around with it.
It was the same as the left headlight... the left headlight fuse also works for the leveler. As soon as i changed the fuse the light came on and the motor started whirring
