Phase "quick" PIC HEAVY
  C63 AMG, F430 & 172
Quick list of the spec..
engine
Full engine rebuild
OMEX 600
OMEX race loom with renault ECU delete
Jenvey 48s parallels
Jenvey ported manifold
Jenvey 120mm trumpets
Jenvey FRP airbox base plate
Jenvey alloy fuel rail
PiperX 600 100mm box filter
Peco 43 injectors
Weber fuel pressure regualtor
CAT CAM 422's (vanos cam)
CAT CAM PAC springs
Ported Head
Full head rebuild with new steam seals, guides, inlet valves
Wossner 12:8 High compression pistons
Total Seal ring sets (gapped by headshop)
182 4-2-1 manifold
K-tec link de-cat
k-tec 2.5" stealth cat back
Lightened and balanced crank
Lightened Flywheel and balanced clutch cover
Weight matched rods
ARP 2000 studs (big end)
ACL race big end bearings
Glyco mains bearings
Glyco thrust bearings
New bottom end gasket kit (inc crank seals etc)
New crank pulley bolt
New water pump
New MLS Head gasket
New Head bolts
New thermostat
New oil pump
Full strip down and clean up
Block decked and head skimmed to bring clearance up
Block honed
Renault Cam belt kit with tentioers
Renault Aux belt kit
Cup AUX brackets
Cup alternator
Custom short rad (wider and thicker)
10" 1040 CFM pacet fan
Valeo pressure plate
Valeo release bearing
HELIX autosport organic disc
Uprated engine mounts with solid dog bone
Plus lots of bits i cant remember...
Gearbox/trans -
Refurbed shafts from GSF
Gearbox rebuild (shot peened sp) - JC5
New selector rod
Suspension
Powerflex ARB outer and inner buhes (powerflex blacks)
Leda Coilovers (rebuilt)
Custom rear platforms
eibach springs 320 fronts 400 rears
AST adjustable solid top mounts
New track rods
Brakes
ABS delete
Custom lines and 172 cup master cylinder
Tilton bias adjustment (remote located in car)
Mintex M1155 front pads
Brembo Max fronts
Willwood 4 pots with GDI brackets
Hose solutions HEL ss front lines
Goodridge rear ss lines
Renault rears discs and bearings
ds2500 rear pads
ATE superblue fluid
Interior
OMP cage (weld in) with optional extras :p
Cobra evolution S's
Cobra alloy 5mm side mounts
Cobra subframes
Sparco 3" 4 point harnesses
OMP eyelets and load spread plates
Full interior strip, primed painted and 2k lacquered
Battery relocate
OMP wheel 330mm
OMP boss
Exterior
Cup spoiler
CC mirrors
It needs the suspension setting up still, the rear is too low and the front it a few mm too high, the driving position needs sorting, brakes need a good re-bleed, the front insert for the bumper needs to go in, need to get the tacho working and the top dash back on, passenger seat in and a few other odds and sods...oh and a bloody clean!
Not bad it took just over 3 months to do (the full bespoke engine build took less than 5 weeks which i was pleased with, seems it doesn't have to take 12 months these days)
Its cost a shocking amount of cash but.. meh it goes and looks great imo! cheaper than modding the r32 though, exhaust (manifold, cats too etc), CAI filter, sway bars and a remap just cost £2700 for that :/
a few pics (adams 197 sneaked on a few)
oh should see you all at fcs! fingers crossed!
  172 Race Car
Looks good, engine bay is very nice. gonna finish the dash off?
How different is the Cup master cylinder?
@rt
  Veccy 1.9 cdti
looks amazing, what a spec list!
not usually a huge fan of ph-1s but this is one mighty fine track ****!
  C63 AMG, F430 & 172
the rear doesn't over take me anymore lol, i changed from a cheap bias valve to the tilton one at the same time though! i got it off ebay it looked the same as the non cup one, renault said it was the same!
So I would guess the tilton fixed it
Clart
i bet that weighs next to nothing with big power. Should be fun - get the suspension sorted and u'll be embarassing a lot of expensive machinary on track.
Owen
ClioSport Admin
And to think I can't even be arsed to jack my car up to clean the insides of the wheels!
Awesome bit of kit there Ben. One question tho, whats the red screwdiver-esq handle by the instrument panel dimmer control? (pic 14 i think)
  C63 AMG, F430 & 172
remote brake bias adjustment
  TTRS & V50
Loving the ph2 rear and ph1 front, proper beast this.
Love everything about it. I'd just take the front down a tad and leave the back.
  lift number 1 @ btm
good work sir!
what output did you get in the end, i'm curious because my engine must be pretty much the same spec as yours?
Ad
  MK2 FRS
Gutted i didnt get to drive it yesterday. Will be making up for it on Thursday;)
Looks sweet, I was mega impressed with the tidyness of the engine bay!
The Boosh!
ClioSport Admin
  Elise, Duster
Well done ben looks a million times better than when you first bought it.
Was a mega shed!
  Ph1 172 + Combo van
Looks so good that engine bay!
What are you doing with the front? going to get a grill?
  Tesla MP3 2021
This thing is a death trap lol ;)
It will be epic once it is 100%, you can tell already it has loads of potential :)
  C63 AMG, F430 & 172
yeah a piece of shitty body work slots in there
I forgot to put it back on when i fitted the bumper, then thought.... f**k that I'm too tired lol
  C63 AMG, F430 & 172
shush so what if the steering wheel bolt is loose and the it pulls violently to the left when braking :p
  lift number 1 @ btm
fair enough,
i've gone with the quaife, so when it's finished we'll have to do some "testing"
