Naughty Naughty Blue
  alien green rs133
just found this video of the 1.2 8valve on the rollers and thought it should be in here
[YOUTUBE]<object width="640" height="505"><param name="movie" value="http://www.youtube.com/v/cL8A2La2WF0&hl=en&fs=1&color1=0x3a3a3a&color2=0x999999"></param><paramcreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/cL8A2La2WF0&hl=en&fs=1&color1=0x3a3a3a&color2=0x999999" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed></object>[/YOUTUBE]
sounds alright on full chat ;)
Chris205
  Many Things
I had my inlet manifold ported on my megane k4m engine and it seemed to make things a lot smoother
  alien green rs133
UPDATE
she is almost ready to drop in
ill let the pics do the talking
once i was happy with the do-it-yourself head porting, i took advantage of the in house parts washer (strangely my mum had no problem with this :S)
came out nice and clean :D
next started to tidy up things, block went from this
to this, a few coats of hammerite later
once that was sorted it was now the dreaded task of fitting honda fireblade motorbike throttle boddies onto a renault 1.6 16v cylinder head..
4 bits of alloy tube and a modified inlet saw some progress
so thats a rough mock up now just gotta make a round pipe fit a almost square hole and weld it to a modified inlet manifold...
i machined the inside of the tube out to match the diameter of the itb's then squashed the ends in the vice, leaving 15mm at the end to aid matching once welded together, heres a look down through one :D
while the inlet manifold was away being welded, i decided to paste the valves in.. time seemed to stand still when i was doing this. concidering the state of the inlet seats i decided to take the exhaust valves out aswell. they were worse, and while valves were out i cleaned up the casting marks in the port, not taking the kind of material out that i did on the inlet, just making it smoother for air flow.
the head was also sent away and i got 0.5mm skimmed off :D
the block was cleaned with 600 grit paper and dw-40 (yes dw-40, ripp off of wd-40 much)
then it was finally time to put things together
new water pump
new head gasket
new timing belt
ohh and i painted the rocker cover green, it is the green machine after all :D
proud of my itb's :D
and dont worry the alternator setup isnt finished yet :rasp:
just gotta sort the mounting for it and thats about it the engine can go in the car :D
cant wait
hutchie
  alien green rs133
What power you expecting to run?
be happy with what i get tbh, once its running in the car im sticking some cat cams in, then i will be aiming for 140-160 bhp :D
and its getting rev'd till the valves come and dance on the bonnet :D
  alien green rs133
ok so it has now begun to take shape
time to say good bye to this
and its replacement lined up :D
and in
and we only started a 5 in the afternoon to take it out :D new one in at 9, with new exhaust and most things connected :D
gotta get tip on exhuast sorted but thats no biggy at this stage
thats todays progress should have it home tomorrow :D then start wiring it up and get the girl running, he says hopefully
hutchie
stay tuned....
Hutchie, im f**king so so proud to see you was taking use of the dish washer.....Epic performance that youth!!
car is looking ace, very good work mate;)
xx
Sam
North East
WOW. Its flying along. How long you think it will take to get it all wired up and running hutchie ?
  alien green rs133
im on with it today, but as usual its not straight forward
but some good news my injectors are 11 ohms :D :D :D chuffed
i think to get it running im just gonna use the standalone to run the fueling. and the cars own ecu can manage ignition and advance on timing.
that way i dont have to work out how to use knock sensor with stand alone :rasp:
hutchie
ps. look at the engine mount. non clio item, but its really really sturdy :D
  DCi 100
I'm alittle confused, your doing this work on the 1.2 engine or bigger?
Edit: Found it, some crazy amount of time gone into it, will all pay off when you get to drive it!
  alien green rs133
i will be happy if it runs tbh :mad:
does anyone know if the abs and speedo work on a 2002 mk2 ph2 when the engine is off but ignition still on? ;)
hutchie
Brett
  320d
Great project mate. Realy impressive stuff. Wish I had the know how to do something like this.
  alien green rs133
well that will do for my tonight :eek:
[youtube]<object width="660" height="525"><param name="movie" value="http://www.youtube.com/v/A8-UidIlf5Q&hl=en&fs=1&rel=0&border=1"></param><paramcreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/A8-UidIlf5Q&hl=en&fs=1&rel=0&border=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525"></embed></object>[/youtube]
notice pooof of smoke :rasp:
