Front windscreen wipers have stopped working on a 55 1.6 Clio ... Rear wiper still works fine. Checked both fuses and cannot find an issue so do you think the motor has gone and if so is it an easy job to change ?
Im going to check the relays before i replace the motor
Going to have a look at her car later this evening and ive just been out to have a look at mine. I belive my relays are in the fuse box in the engine bay (to the right) but mine is a 2.0 so it may be diffrent ?
I also cannot see how i can tell which relay does what as there not named or numbered in a way i can tell. Ive had a look through my manual and allthough it does explain how to change a fuse it says nothing about fuses and infact nothing about the fuse box under the bonnet
Took off the top shroud on the steering column and one of the connectors had come lose. It recently had a new part behind the steering wheel as it had burnt out (for the horn)
Since i was playing around with the relays the auto headlights have stopped working ? I may have swapped the relays around so they may not be in this original positions ... Do you think this would be causing the issue ? Is there anyway i may have disabled the auto lights and if so how do i re-enable
