So, found myself wondering wtf a dephaser was and how it worked......
Car  2003 Clio 172
And found this
Apologies if its a repost, but i found it enlightening at least.
I came from Honda land where variable valve timing was a VERY mechanical affair.
All i saw under my little 172's hood was a funky little cam gear and just wanted to know how it did its stuff.
JJ
Interesting read! I was especially interested in this part:
It is a "joint" fault of Delphi, who supplies dephasers, and Renault, who did not test this part sufficiently well. An option is that testing was done on a prototype engine before it was enhanced by using "racing" style hard springs and cams with roller rockers.
Renault discusses this problem in their technical note TN4432A.
This is it, I guess. The problem is down to lubrication failure and poor design by Delphi.
Intresting design that. Ford uses like a screw thread on the VCT pullys on the 1.7 puma engine. The Ford unit is much more complex but you never hear of it going wrong.
another question to this topic;
When having a full cambelt change , is this dephaser pulley also changed or is this an extra ?
^^ that properly sucks !
So, when having the cambelt done and the dephaser goes shortly after ; it means the whole job all over again !? (with all new parts , belt etc. )
The more you see about these engines/cars, the more you realise that they are actually designed to be money magnets afterwards....
Seriously though.
Surely its possible to design an engine that can have the belt changed easily AND fit in the car.
But no, lets just remove any notion of timing marks and even tensioners and use our own tools
French
Meh!
Anyway, do they not do the whole taking the dephaser off and cleaning it thing when they do the belts?
Jj
I was assured I had no need to worry when I suggested replacing mine while the belt was off. This was less than a year and 5,000 ish miles ago and I'm not looking at the cost of both belts yet again with the added cost of a dephaser thrown in for good measure.
It makes me sad these things..
mine is fine but i can imagine how you must feel. I would go back and try out their after-service, + if that does'nt work tell them they're a bunch of incompetant assholes
I just had my dephaser, aux belt and cambelt done 2 weeks ago for £370.
Car feels so much better and the quietness of the engine is heaven lol.
The perfect argument of "it was working perfectly when we worked on the car" or "we cannot predict the failure of a part" is on their side. They could also argue that if I'd asked about it and was that concerned that I should have insisted it be changed. Would be an utter waste of my time to go the route of kicking off IMO, all I'd be doing is wasting more of my money on phone bills and time.
Hold on, I thought the dephaser was lik £160 and the belt kid were like £100 a piece?
Surely that's only the labour charge?
true that, still they have to learn about these probs for future customers
I'm sure if you spoke to Renault customer service you could negotiate at least a better rate tbh.
I mean, parts aside, my recent cambelt and aux belt set me £170 in labour costs. Not bad for a Reno dealership tbh
Dephaser was £98 from Renault, Aux belt was £12, Timing belt was £89. Rest was labour, baring in mind mines is in a Megane Coupe.
The cynic could also argue that you say nothing about the dephaser or dismiss it as being an issue then pick up extra work giving it the "oh that's unfortunate" line when the owner rebooks to have you replace the belts again along with the rattling dephaser.
Wasn't done by Renault, was an independent specialist.
Is there any vids on wat this sounds lije? Or syptoms? Lods of power etc? My engine makes lots of funny noises! Rather concerned now........
Mines lost power, Used to sound like a diesel when it was warm and the noise would die out at 2.5k revs.
Sounds like a diesel, a very loud diesel - very unmistakable.
People are however exaggerating the frequency with which the fail, I would estimate we change one a month from around 10-15 cambelt services.
Yes we change around one a month, thing is when people phone for a cambelt quote and you mention the dephaser pulley is recommended to be change and that adds £150+vat to the job they tend to think you are taking the piss and you end up losing the job. It's a no win situation most of the time.
We find most people don't want to spend much on car repairs and servicing.
yeah, we never change it unless it's on it's way out or the customer specifically requests it. We have only ever experienced one car that needed another cambelt service post dephaser fail, and we sorted the chap out with a good price.
I said I was happy to pay for it to be done while the car was having he cambelt change as I'd heard other people mentioning they fail but had my mind put at ease. In hindsight now I wished I'd insisted it was changed.
Don't see it failing really, unless they are bad serviced cars, long interval oil changes and wrong oil specs will make that part to fail, also doubt the pin isn't to the correct spec (material, hardness, etc) afterall it is an OEM part and all durability tests are done following makers recomendations, if you fall out those you are testing it for yourself and at your own cost. I am invovled with an OEM company, and in my opinion, all faults of this type are almost always due to: not following maintenance shcedule using recommended stuff or a faulty part (bad luck), which always will be around.
If you see the design the pin wears out in a very typical way of a not well lubricated part and that is mainly due to poor servicing or not using recommended oil. So change your oil as stated, use recommended oil grade and don't thrash it when cold. if you do this and still fail the it can be even a dodgy oil pump, engine block, etc.
Other than that I don't see it failing because of a design flaw, or we wouldn't see so many very high mileage cars. Mine is 70,000 (not particualrly high) and does not tick/tap a bit, but has been serviced religiously
