Is there a difference between the 172 cup and trophy wheels?
  Discounted 1*2 parts
nice one cheers guys. i want to give my 182 a wider look (and to fill out the arches) which should i go for?
i can never remember if a higher or lower ofset makes them stick out more!
and i presume they will fit on a lowered 182? at the moment i have aibach springs fitted but maybe looking to get coilys in the future
thanks for the swift responses guys :)
  Inferno 182 FF
I have cup turinis on mine, on sportlines, and i want to get coilovers. Not a prob with the sportlines. Would like to know if they will be ok on coilies!
  4 wheels
if you're planing on lowering alot you will want the trophy turinis due to them being the right offset for the cup packed 182s
Jamie
I was under the impression if you have a 182 Cup you HAVE to have Trophy wheels. If you have a 182, either Cup or Trophy wheels will fit.
  monaco 172
Can I just bump this thread, looking for some turninis and am just wanting to know if the only difference between the 172 cup and trophy wheels is the colour and offset.
Ie do they both weigh the same?
Gaz_
  Extreme mode
Nope. 172 Cup Turinis are Silver, Trophys are Anthricite
ripp
  182 FFAT
if you're planning on lowering get a wheel with the closest offset to 45, thus you'll prevent rubbing on the arches (and even so it may appear but it will be smoother and easier do get rid off).
so get the trophy wheels :D
  Dodgy one
I have 16x7" ET37 Superleggeras on mine 182 cup packed! a whole 1mm further out than cup turinis lol, Approx 40mm if a tad more from factory height and only get rubbing with a fair bit of weight in the back, or absolutely hammering it down a bumpy B road!
  monaco 172
They are the same price new from Renault iirc?
On here tho the trophys are more expensive.
I don't plan on lowering it but my car has got both cup packs so it's slight lower than standard. So does this mean that if I get the cup wheels theyl catch on my arch?
