TrackCar & F30 330d
OH just thought, you should have got the cam cover powdercoated whilst it was off, Laxy's enigne looked amazing with that done
All looks very pretty Tom
Not so sure on the spacers though, i've never been a fan, see way too many failures to even consider them, especially for a track car.
We have had no problem all year running them.All looks very pretty Tom
Hubcentric Type B spacers Dave, they aren't going anywhere!
Dave you'd need to bore out the centre bore to 60.1 to fit them style of wheels, would still be easier though and cheaper than spacers.
Fair enough, im just not a fan, id rather just gets wheels that give the correct offset from the start.
FYI the e30 4 stud BMW's use 4 x 100 PCD, with ET15 & centre bore of 57. With a spigot ring that would give you a direct fitment & similar offset to a ET38 with 20mm spacer - if thats what you're using.
Good point, slight typo on my part.
Spigot ring would be used to go from 60>57, machining for the other way round, ie 57>60.
I got the impression Tom doesn't even need to wash his hands at the end of the day![]()
Tom, what width spacers are you using on front and back of yours?
Your opinion is wrong
Pulls the seal in nice and straight and to the correct depth, no valid reason not to use it if you ask me!!
Standard cams, for now. Power is not of concern at the moment, the primary objective is the driving character and my ability to master it!!
