Rear brake discs is stuck! I can't get it off
Car  Looking for 182
Hi all,
I've removed the brake caliper and also the 30mm nut, the hub is wobbling a bit but it won't come off. I've hit it with a hammer and wood but it won't budge. Do I need more welly, or have I missed a bolt somewhere?
Thanks
MAKE SURE YOU SAVE THE BEARING SHIMS! - if you even have them!
I didnt have any when I got my rear discs replaced and the new discs wobbled like f**k when all was put back on
I NEARLY missed them, but then found it on the floor after fitting the discs, and realised!! Phew! :)
It's been a productive day, fitted new rear discs and pads, dremeled off the bumper bracket to hopefully stop my wheels rubbing, resealed the exhaust join between cat and the bit leading to the back box, and now I've given it a big old clean in time for the Southend meet :)
