how to attach mud flaps!
  MK2 PH2 1.2 16V
awright guys,
are mud flaps easy to put on yourself or am i aswell paying a few buck for them to be professionally done?
cheers:cool:
  Jap Box
Welcome by the way :)
Struggler
  Ph1 track 172
is there anywhere that specialise in mudflap fitting?
they look guff, end of,
dont bother putting them on for the sake of slapping a mod on the car!
TheEvilGiraffe
You think that they will protect your wheels ?!
Better off putting a binbag over each wheel. Probably best to use those rubble sacks from B&Q as they are a bit sturdier.
Failing that, get the bus.
Darren S
Mudflaps are a dirty word on CS (apparently?). One mention of them makes everyone think you'll be attaching a ground-hugging 5ft x 6ft section of red plastic and splattering Sparco stickers on them.
They should be available as standard - or at least have some form of cill protector attached to the front wheel arch.
D.
  Listerine & Poledo
There are moulded mud 'flaps' that you can get.
They look far less gash, provided they're colour coded to the rest of the lower trim.
Christopher
  Z4M
Moved the the CORRECT forum.
Also, changing the typeface and colour makes it really annoying to read.
i have plain black ones on my 2 cars.
but then again our main roads are worse then yer country roads TBH
all you need is a screwdriver and 16 "self tapping" screws.
i might take pics later but right now it's pis*ing
