Well was fitting a set of fogs to my car today and was wiring it all in... all was going amazingly well right up until the point I started the engine....
It runs for 3 seconds then cuts out, the head lights dont work, nor do the side lights, the front incdicators dont work (on the wings or the head lights) although all the back functionality works... lights.. indicators... the lot!
So I think I may have knocked a wire loose at the back of the fuse box im praying to god right now there is no way I could afford an ECU
Anyway any light on the situation may help all fuses are in tact in the passenger side or under the bonnet. Nothing has tripped imobiliser light goes out when key is turned serv light is constantly on the ABS light is on (I dont have ABS) my mechanic couldnt get into the ECU with all 3 of his machines they couldnt communicate with it so im assuming this points to a wiring problem
Nick
Nick
