Engine wont run for more than 3 seconds.... :(
Well was fitting a set of fogs to my car today and was wiring it all in... all was going amazingly well right up until the point I started the engine....
It runs for 3 seconds then cuts out, the head lights dont work, nor do the side lights, the front incdicators dont work (on the wings or the head lights) although all the back functionality works... lights.. indicators... the lot!
So I think I may have knocked a wire loose at the back of the fuse box im praying to god right now there is no way I could afford an ECU :mad::mad:
Anyway any light on the situation may help all fuses are in tact in the passenger side or under the bonnet. Nothing has tripped imobiliser light goes out when key is turned serv light is constantly on the ABS light is on (I dont have ABS) my mechanic couldnt get into the ECU with all 3 of his machines they couldnt communicate with it so im assuming this points to a wiring problem
Nick
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
How exactly have you wired the new fog lights? Don't spare on the details please.
There is the loom which runs from both fog lights to the relay then a wire from the relay to the positive on the battery then a wire to the negative on the battery (I removed the negative terminal to do this) then 2 more wires from the relay run into the cab where they wasn't connected to anything just yet
Rob
Whhhhhhhhhhhhattttt
Why there there a wire to the negative on the battery??
You don't need that.
FFS, I'll dig out my old paint wiring diagrams...
Rob
Whhhhhhhhhhhhattttt
  Astra 1.9Cdti SRi
Im pretty sure theres a connection on the engine loom ready for the fogs lights allready, there is on mine so should be on yours :/
My car never had the fogs as standard I bought a secod hand full set off eBay
Fogs and surrounds
2 looms ( the loom behind the bumper and the loom that it connects to with the relay)
Relay and inline fuse on the live wire
And indicator stalk
I disconnected the battery took each fuse out one by one then checked them all put the positive back on the battery then the negative locked my car with the key fob unlocked it then tried that and failed
PHEW! got it sorted thanks guys... I was messing under the bonnet and scuttle yesterday and unbolted the main loom harness from the car and never bolted it back on -.-"
Right... lets here the names... lol
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
School boy error...
They came with the full kit so im hoping genuine :) lol
and Yep all wired in correctly if theres a flat battery thread... Ill give the fog lights to someone else on here free of charge from my trouble ! haha
