Ollie's Silver Cup - JMS RS2/Wilwood/2118
Re: Ollie's Silver Cup - JMS RS2/428s/Wilwood/2118
From doing a bit of CS research, unless the design has changed since they became available again, it seems the Yozza stealth shares the same pipework as the yozza race system; the difference between the two being the backbox. Meaning it also uses the 63.5mm diameter and the race and stealth rear boxes are interchangeable? :)
So, really now my two options to consider are the Yozza stealth and the BTB stealth, £399.00 and £449.99 respectively.
Oh and photo from the entrance to FCS;
Also, things to do over the summer;
Engine finished - RS2 intake, 428 cams, hoses, catch tank, etc being fitted at JMS on July 18th. (my birthday ;) ) Will be mapped as soon as possible afterwards at RST.
Sort new exhaust - as above, either yozza or BTB stealth.
New carbon bits to replace the current ones - proper streamline pre-preg this time around.
Recaro PP or Furious fixed seats.
Done! :evil:
You can get the race system but with a stealth tip iirc.
So no bumper cutting but the epic race noise.
Id go for a yozza mate. Has it got spacers?
No mate, spacer free for now.
I think it could do with some eventually. :)
That was going to be my choice, Mike.
But, I didn't really want another loud exhaust.
As an everyday car, I'd sooner find something a little more refined. I'd still like to know it's there, but not be too loud. :)
Couple of bits to get sorted tomorrow.
The drivers side CV boot clip has come loose, meaning I've got grease slowly covering my wheel! Also, the exhaust mount will be swapped over tomorrow too. :)
Sorted. The Prima competition exhaust mount is very good, wish I'd have opted for it sooner, rather than messing about trying to bodge repair the old one!
So, the old exhaust mount looking very tired. Bearing in mind this photo was from a while ago, so it's in even worse condition now!
And the new Prima competition mount fitted, no more sagging rear box;
It's also cured the issue of the exhaust reverberating through the car, which was driving me mad!
Very impressed with the product, would recommend. ;)
I think the K-Tec exhaust will still be replaced though, as the drone at motorway cruising speed is equally frustrating and I think I've slightly grown out of the noise.
Aah so this is the thread i missed! :o
You've got deep pockets mate... great uprated parts though.
I've decided to run aerocatches. There's a couple of reasons; my car never had the bonnet catch recall done and they look cool. :evil:
Once they're on, I think the slam panel may go.
I'm hoping to get a few replacement bits ordered from streamline soon too!
Anyway, photos from Sunday. They've been posted in a seperate media thread because I was happy with them, but thought I would pop a few in here also;
What do you think to the GAZ set up on your car? Would you recommend this kit or would you recommend something different?
Car is looking good as always. Love the wheels. Was good to see it in the flesh at FCS! :)
Looking good :approve:
How much was the exhaust mount, and where from?
I initially ordered them before reading some of the 'horror stories' regarding them on here (leaking, etc); I had a Ford previously where they were highly recommended, so based my choice on that.
After seeing some of the comments on here after, I was a little worried that I'd have problems with them, but, to be honest they've been on for over a year now and I've never had a single problem.
The only problem I had with them was when ordering. I ordered a kit for a 172 cup and received the 60mm hole spacing version, which were obviously no use for my car. It was a bit of a battle to get GAZ to replace them; they continuously argued that 60mm was the correct size and that 172 cup and 182 cup shared the same suspension fitment on the front. Eventually, they agreed to swap them over for the correct ones.
I feel I've got them set-up in a way that's pretty perfect for my needs, also.
With regards to the fact they've been (so far) reliable and I've been happy with the handling, I would recommend them. Cost wise, they're available for pretty cheap too.
I think though, if I was buying again now, I'd spend a little more and consider a more premium german brand (KW, Bilstein) or even the new Spax kit from Danny at 519.
It's from Prima racing. They're £35 each iirc (plus delivery £9).
Really really impressed with it actually; I wish I'd have bought it months ago! :)
How are you finding the new steering wheel? I'm considering one...
So when are you getting all this kit fitted and mapped fella
Oh his birthday! 18th of July I think.
If you use areocatches and remove the slam panel then the top of the radiator will flop forward and backward and it may hit your fancy carbon airbox. So there are two options you could do. Buy a shorter vag rad for £40 (same as mine) and a slimline fan (£30) eBay jobbie. It works fine and the fan does cool the engine when its on. OR get some cable ties and tie the rad to your bumper like I had to do. As your having the hoses done then changing the rad would be a worthwhile thing.
Really like it. I find it to be the perfect size! :D
Brilliant value too.
As Chris said, it's booked in at JMS on the 18th July. So about 2 weeks time.
Hoping to get the RS Tuning for mapping the same week, or the following week. :)
I definitely want to run aero catches, just undecided on the slam panel at the moment.
Did the rad connect straight up to the hoses? Or, did you have to modify anything? :)
I seem to remember the link to your rad being posted (in your project thread I believe) so I'll have a look later! :approve:
I thought the whole concept of the JMS set up was that you didn't have to modify the slam panel?
Think your RS2 is gonna be on before mine :(
My cars still down with the JMS boys trying to get to the bottom of this wobble, bad times... New shaft didn't solve the issue.
I wouldn't take off the slam panel if you don't have to, aero catches are mint though.
The hoses are in excactly the same place and they fit spot on. I'm sure JMS could knock up a small bracket for the smaller rad. The info is in my project thread, its in big writing i think :)
Removing the slam panle will make it look neater and if you trim the grill like mine then it looks really neat :)
You don't have the modify the slam panel, it fits in perfectly without any cutting/moving :)
I just like the neatness and look of running aerocatches without the slam panel.
Hmm that wobble's turning into a bit of nightmare! What's next to try? :(
It's just personal choice really, it could be easily swapped back if I was to cut up a replacement grille/panel :)
I'm going to have a look at the info in your thread today.
I'll probably sort that after JMS have had the car, I think. :)
I'd be trimming it, like you have done.
Fingers crossed you get a good result/gain/feel after the conversion!
I'm intrigued to see how the RS2 performs alongside the 428's :)
Hopefully the combination will be a success!
Not long now.... Your gonna beat me to having yours fitted!
My car is still down at JMS :(
I'm interested to see as well. Are we allowed to place bets yet? ;)
It's a difficult one to predict really, as I can't think of many cars running an RS2 with uprated cams. I'm hoping they will compliment each other nicely.
Although it would be nice to pull impressive figures, as long as it drives and responds well, I'm not too fussed. :)
Your ITB'd engine is running aftermarket cams too, isn't it? :cool:
Also, unrelated to performance, but a while ago Tom mentioned that the carbon section of the RS2 could be polished up with a DA if desired.
As I had some free time this morning, I thought I'd give this a shot.
I used Menzerna super finish light compound, on a finish pad. Really pleased with the results, the carbon now appears to have so much more depth, gloss and detail to it. :D
Any closer to getting the problem resolved? :(
About to speak to Tom and give the go ahead for a New gearbox! Its about the only thing left now it can be! The car will probably still be down there when you drop yours off, although I am told my RS2 is on and all my Pipes so feel free to have a look and see what your finished Item will look like ;)
I applaud you for your sensible expectations, but im afriad it might be too uncontroversial for this place ;)
Looking good Oliver!!
I'll hopefully have a look at yours on Monday. Did you go with the Forge pipes in the end, or the SFS ones? :)
As you've said, the gearbox is about the only thing left that could be causing it! Nightmare!
LOL! :approve:
Being a resident JMS associate, can you remember if any RS2's have been fitted alongside aftermarket cams? :)
I know James' ran with the C&B ones for a while?
Thanks mate! :D
Mine needs this doing but alas, I cannot be bothered lol! Not long now :evil:
