Clio 197
I've not really looked into the options previously for replacement mounts, but there didn't seem to be much available. I had the OE mounts for 4 years before they started to fail, replaced them with aftermarket mounts available but they have lasted a little over a year.
SO..... I bought 2x Powerflex universal exhaust mounts EXH 008, about £6 / £7 each. Pic in this link
http://www.powerflex.co.uk/i/product_images/2-Exhaust Mount Cat Page.pdf
I cut the useless rubber mount flush from within the metal frame so it left a nice opening to fit. They're not a direct fit into the standard metal mount and required approx 3 - 5mm taken of each side so I still had to compress it to get it in place. cabled tied in place to ensure it can't fall out (unlikely but just incase). All I have to do now is find a 12mm drill bit and make the hole for the hangar arm.
New exhaust arrives in a couple of days so I'll make final measurements then and get them fitted.
No more sagging :rasp:
Just wanted to say cheers Yellow Dave, i saw your guide above and fitted my powerflex exhaust mount to my cup - hopefully should last years and the exhaust is now very stable
If anyone else is interested you can get the EXH0008 powerflex insert for £5 delivered from eBay
