ELF SXR Oil from Renault price?
Car  Impreza Wagon
What's the going rate for ELF SXR 5w40 from Renault. I was going to pop into town and get some at lunch but I'm not wanting to get ripped off.
I usually use Fuchs however I thought I'd try ELF for a change as it's recommended.
Thanks that'll save a journey out :), also how many litres of gearbox oil do I need? I pressume it's a case of fill it up until it comes out the top?
3L just keep filling till its all in or its coming out the breather.
Box is 3.1L but you never drain it all. I put the Elf Tranself NFJ - 75w 80 in which is the specified, but i know a lot of people use a 75w 90 semi synth which is fine and also a bit cheaper.
No no no
Filling till its flowing out of the breather is way over filled!
The correct level is when it comes out of the hole on the front of the box which is covered by a plastic butterfly nut.
If you go to any Total garage they will have Total QUARTZ 9000 fully synthetic 5w40 oil.
Its exactly the same as the ELF stuff.
£25 or so from garage if they have the 5litre on the shelf.
I know that fully synthetic oil is specified for the gearbox, however if I am changing the oil regularly (every few thousand miles) is it ok to use semi synthetic but of the same grade?
Nice little tip, thanks :) I always wondered about oil rebranding!
No no no
Sorry I meant the hole at the front. Thats where i put it in from.
you're right, it's the exact same stuff as total/ELF is the same company. I'd be shocked to find 5 litres of any oil for less than £40 in a petrol station though
