headlamp - can this be fixed?
Car  A.N. Other
Found a broken adjustment clip inside the driver's side headlamp, the reflector is loose & moving around and the beam pattern is low.
Does anyone know if they can be bought separately or successfully repaired? I was thinking araldite, or some repair putty. Only problem using the putty might be adjustment later.
All my xenons are like this. (I did get them for £70!) You can secure it with cable ties and glue but it's abit of a bodge!
Do the headlights have motorised adjusters or manual? Is this where they have snapped? If so replacements can be bought 2nd hand and are a fairly easy replacement
Tried pulling the clip out of the ball&socket so I could glue it back together but it just broke apart as I pulled it out - grrreat!
It's broken into too many pieces to put back together now :mad:
This clip is for a manual adjustment on the RHS of the driver's lamp.
How easy, is it to take the headlights out?, i know its a bit off topic, but i wanted to change the dip beam bulbs!
You can buy them on eBay 2nd hand, mine failed it's test as they were both broken
Just tried, and there aren't any on there. Just hoping I can botch something together from the bits that were left + repair putty.
Regarding removing the units, there is a guide in the Tech Guides section, just have to remove the bumper which apparently is fairly easy.
