A.N. Other
Found a broken adjustment clip inside the driver's side headlamp, the reflector is loose & moving around and the beam pattern is low.
Does anyone know if they can be bought separately or successfully repaired? I was thinking araldite, or some repair putty. Only problem using the putty might be adjustment later.
