I need some stuff
lol i has a tubular manifold :cool: bit of a homebrew tho lol
im not sure, the rails are in the garage now anyway so i will check tomorrow. might make a call to my mate with a 172 for a cheeky pinch of 1 or 2 injectors :evil:
shitter :(
same sized o-rings each side but huge diffrence in size :(
Check the dimensions lower down the page they look as though there very close, try and grab similar measurements to see what, if any difference there is
lol its not on there! ive looked several times for dimentions :P
i did find this however which means theyre 4mm too short.
sure i could make them fit!
I used those exact injectors on mine and spaced the injector rail out to accomodate them, never had any problems with them. Think they were about 70-75% duty cycle for 374bhp. Should give you plenty of scope for big power especially with you going down the VAG gearbox route.
lol im a bit affraid of big power atm lol. not affraid to admit it either!
will buy thejm on payday then :) very nearly there then! thanks a lot for your help mate, its been invaluable!
edit: am i right in saying that they are only £128 for 4?
$197 for 4
is that £161 not including the import fees then? i used their quote button for a quote to ship them to my address and for a 4 day delivery it came to $53 ish i would assume thats all in being as theyre only little things...
it saves me £60 on buying that set on ebay if it is all inclusive
Negative mate, when it arrives in the UK it'll have import duties slapped on it as it passes through customs, it's nothing to do with the company you buy them from
Just found a Fed Ex import duties bill from April last year, I ordered full ARP head studs, main studs and con rod bolts it came to a paltry $234 :) when they arrived in the UK i was billed £38.86 in import duties and handling charges.
Should give you a rough idea of what it'll all total
I run Siemens Deka 'stubby' 630cc injectors on my Megane..
Paul at RStuning provided them, they are the same physical size as the standard injectors.
Make sure they are flow matched aswell!
its for an F7R mate so the stubby ones wont fit infortunatley. im going to take a punt with the longer ones i think tho :)
