Soooo... Putting my 182 back to standard to sell. Changing coilovers for standard shocks and springs
Rears went off and on fine. No trouble there.
However, front coilovers have come off fine, but I'm just bolting the front strut assembly back up, and for some reason the bolts holes for the hub aren't even remotely close to lining up with the bolt holes on the shock absorber.
As you can see here the front shock is sitting a good two inches below the required height.
I re-assembled in what I believe to be the correct order: Spring - Metal cover for spring - bearing - bottom rubber donut thing - top hat - 17mm retaining bolt - through the bodywork - then the top mount.
Anyone know where I've gone wrong? Bear in mind the shock is currently just hanging by the top mount so is suspended and free to move in all direction apart from up and down (which is sort of where my problem lies)...
Sam
Sam
