I actually want to cuddle you Phil
Hahahah sort me out some money off a Spax setup instead
It's not s**t on track compared to a standard car - it handles well
But it's waaaay too soft for track use. I've taken well over 150kg out of the Clio and put a 60kg cage in - the cage is all on the rear half of the car - as is the battery
It tends to understeer and when I had it properly setup I was advised that understeer could be dialled out by tweaking the damping rates on the rear - but I can't
Bilsteins are REALLY NICE coilovers - they don't rust (had mine over a year now), they're very well made and when the car had a full interior in they were just right
In all honesty though, and people will not like this - they were almost identical to my old eibach springs and standard shocks - just you could set the ride height
For the price tag - you can get spax and the spax setup are just as well made from what I've seen and fully adjustable
Which makes spax the obvious choice for this budget because you can soften them for day use and get them setup properly if you're using them on a track car
It's just insane trying to argue that a set of shock absorbers pre-set to be right for a standard 172 are right for a track car - when for the same money you can get a completely adjustable setup
Oh and also with everything stripped out of the clio I can't get the rear low enough on bilsteins - whereas with the new style spax setup I could corner weight it to my hearts content![]()
Much better post!I don't disagree that it's not a compromise, but I'd be surprised if changing the weight distribution was that much of an issue for general trackday use. I'm not saying you're wrong btw, I'm eager to find out tbh after getting mine set up as best possible. One thing I would say in your case is it seems to be more of a budget than general need. There are far better coilovers with adjustable damping than SPAX out there
I paid £200 for my B14s, so I think they'll do me for this year![]()
On the flipside, if you have done all of your braking 200m before the corner, & there is subsequently no weight transfer to the front axle, you will still understeer - even with R888's, AST's and some Spax coilovers made of 21ct gold set to full hard on the rear.
Some people focus too much on the setup & not enough on the actual person behind the wheel imho.
My Trophy would understeer like a pig if i drove like a pleb.
Quite clearly neither of you have ever seen or been in a Clio Cup Race car?
They're solid - and I mean ridiculously solid
And it's a bit daft saying "the most important thing to change is springs" because if you change springs you need to change damping to match - so adjustable damping is JUST as important and swapping springs. Which yet again backs up why I say bilstein B14's are s**te for track because they're completely unadjustable other than height
I don't understand some of the views in this thread. Having done many trackdays in different cars over the last 4 years, it's a given that you go for adjustable height and damping with higher spring rates when you build a car for the track. Any other view is nonsense.
BUT the whole point of this thread is to recommend a TRACK setup with a £1k budget lol
And im trying to remind everyone that people actually go on track for a number of reasons, mainly the following:
Racing & laptimes - to include circuit racing, hillclimbs & autotest (which will all require different setups)
Trackdays & fun
These two main disciplines may require entirely different suspension characteristics, which is also dependent on what the driver is trying to achieve. To blindly say, OMG you need fully adjustable coilovers, otherwise you will be doing it wrong, is entirely retarded imho.
At the end of the day, how many people on here would actually how how to fine tune their 'fully adjustable' coilovers to offer the best 'setup' for not only themselves, but each & every track they go to. Maybe 0.3% of the CS membership. As such, their is a fair arguement for going 'fixed' and simply learning how to drive the car around any problems that you may uncover.
Many people tend to run before they can walk tbh.
I have a cool grand to spend an a decent suspension setup.
My primary objective is the handling, something solid
I like Bilstein very much but I can't help thinking that I might want the adjustability at some point
its standard atm but the strip-out its very tempting and likely to happen sooner or later.
I have camber bolts and I'll be getting an ARB later on
If I wasn't planning to track my choice would definitely go to B14's.
I want to have fun and I don't mind if the car puts me on the spot every now and again
Such a waste of money spending £1k on suspension for a road car. Standard is perfectly capable for track days. Less body roll does not = faster.
/comment about strokes and folks
Hahahah sort me out some money off a Spax setup instead![]()
I have a set on the shelf![]()
I get the feeling most people replying here haven't read the thread - so I summarised it
Standard car, getting camber, getting rear ARB, has a £1k budget and wants adjustability for the future
Wants fun on track and doesn't mind if the car puts him on the spot every now and again
You believe that you should adapt your driving style around the limitations of the car. I believe you should build a car to match your driving style.
You class a fun trackday as just going round quick and not getting bothered about a bit of understeer
Still depends entirely on what you want from the car though.
My Trophy is standard damper wise (non adjustable), but with the addition of a Whiteline ARB, Sportlines & -2 degrees front camber. Its not the fastest setup im sure, but offers imho considerably more 'fun' than a serious track or 'grip' setup would - at the end of the day, on a trackday, im chasing enjoyment, not laptimes.
I'm a newbie here so I won't go on and upset anyone but will just say this. The enjoyment for me is, as a by product, the lap time. If I am going faster, I am getting the lines better, the braking better, the geometry working better, the tyres working better, the car and driver (as a system) are working in harmony. That's the big kick for me.
If someone wants to go around a track in a car set up for the road with its high roll centre; soft and comfortable spring rates and damping; 'motorway stability' and wear efficient geometry then I guess that is indeed what they want from their car and their choice :S
No I have my own 172 for that![]()
Might do you a bit of a deal if you come and have them fitted though
Want to buy a set of Spax, called you today left message and PM'd yesterday too. No Joy...............:dapprove:
thought I replied to all my missed calls. Give me a bell Monday and I'll sort you out![]()
People on about you don't want to be pissing about with suspension setups for fun track day use....... I like pissing about With setups to see what happens and try and find what's best for me lol
Its all in the track day fun for me![]()
Adjustable coilovers = how would you like your tea? strong? weak? sugar?
Non-adjustable coilovers = tea from a vending machine
Can I just point something out...What you and tommyl said is exactly what I was trying to get at - for 90% of people doing track days "pissing about" with suspension setups and getting faster lap times is the FUN part of track days
There are some rare people like Dave who just want to go and hoon it around and giggle when it goes wrong - but most of us want to tweak the car and get it running better. Which is why I would ALWAYS go for adjustables over fixed for a track car - you know your car and your driving style a lot better than bilstein do![]()
You don't even own damping adjustable coilovers yet
