Ok I will admit I have a problem
After going through:
Mk1 RSi
Mk1 16v
Mk1 16v
Mk1 16v hybrid
Ph1 172 (My itb'd black one)
Ph2 182 LY
Ph1 172
Ph1 172 Exclusive
Duf (Willy 2) - Which I still have currently
RB 182 (Sales car, mind)
I now have another Exclusive lol.
This one I took in part exchange, but I'm going to hold onto it.
Some of you will probably recognise it, as I believe it has been owned by 3 CS'ers and is a good spec:
2001 172 Exclusive
71,000 miles
No Exclusive number - I believe the car is an import (reg document says it was first registered in the UK in 2004, though it has an alarm, which is rare for 172 imports I believe?)
Engine
Remapped with RS tuner
Ph1 airbox with uprated filter
Ktec mild steel stealth exhaust system with decat (I have the cat, this will be going back on)
Green Samco coolant hoses
Bailley polished coolant bottle
Polished inlet manifold
Polished fuel rail cover
Vibrotech solid engine mounts
Powerflex dog bone poly bushes
Interior
Alpine CD head unit
Genesis 2 channel amp
Uprated door speakers being powered by a Genesis 2 channel amp
Fully stripped
6 point 3inch harness's
Corbeau pro series buckets
Omp 330mm suede wheel and boss kit
Rear wiper assembly removed
Suspension
Gaz height and damping adjustable coilovers
Front strut brace
Powder coated wishbones with Powerflex bushes
Powerflex anti-roll bar bushes
Whiteline rear arb kit
-2 degree rear camber shims
Brakes
Fronts have Brembo HC's and DS2500 pads
Standard rears (renewed last month)
S/S brake hoses
Brake fluid changed to 5.1
Wheels
Refurbished OZ Super-T in 16", powdercoated in grey
Toyo T1R tyres
It doesn't owe me very much as it has come with an engine rattle, which is a shame as I can tell it has been very well looked after by it's previous owners.
It seems to have a rattle/tap on light throttle, but very little on load and nothing off throttle, which I think may be internal damage - possibly a bit of oil starvation has damaged a bearing shell - not sure at the moment, so when I get time I will have a better look but to be honest with how cheap F4R's are now I think I will just chuck another engine in it.
Apart from the engine noise, it drives fantastic and is very much like a go kart - the front end is so tight and responds to the smallest steering inputs - very good fun!
I haven't made many plans for it as yet, as said I will most likely have another engine in it, and then strip this one and see what the damage is, I will be removing the polished inelts and fuel rail cover, and will be fitting my spare set of inlets I have (Though I will match them before fitting)
The stainless header tank will be swapped for a standard one, and the strut brace will be coming off too, and I will be looking for some 15 inch alloys to replace the 16's that are on it at the moment.
The Apline head unit might be going as it looks far too complicated for me :S
The interior will be tidied up, the glue/sound proofing removed and the seats will be moved to a more comfortable position for me, and I will keep an eye out for a cheap cage - I may also fit a 172 cup gearbox - apart from that I will just be tracking it and thoroughly enjoying it
Mk1 RSi
Mk1 16v
Mk1 16v
Mk1 16v hybrid
Ph2 182 LY
Ph1 172
Ph1 172 Exclusive
2001 172 Exclusive
71,000 miles
Engine
Interior
Alpine CD head unit
Fully stripped
Suspension
Front strut brace
Brakes
S/S brake hoses
Wheels
Toyo T1R tyres
