205 GTI, Clio 182
				Hi guys,
I've installed some KW Coilovers Variant 2 a couple of weeks ago. I am using Pure Motorsport top mounts. The rear is on the lowest height setting, and the front is on a fairly moderate height. I am yet to set them up properly - it was more to make sure I wasn't rubbing. I wanted to leave them on a couple of weeks so they settled.
Unfortunately I have some knocking and spring tension/binding when going over bumps and low speed turning (in carparks for instance). What are the first things I should be checking when I jack it up? How best to avoid the spring binding?
