abs fault brought up rear left open circuit any advice ??
Car  Nimbus Grey 197
went to a garage yesterday and the clio had a fault being the left rear abs circuit being open i have looked under the car and the sensor connector the white one is all fine dry and spanking under there the sensor looks black and plastic but ok and the ring has no cracks in it and looks ok to the sensor at the front went a little blue/green but cleaned that up and still no joy and now im stuck its for the gfs rb 182 cup
I have the same issue. Was just going to replace the sensor but they're £125.
rear abs sensor on ebay are about £30 if you can do it yourself and yeah iv been on a few places and they have advised that iv looked on the plastic cover to see if there is any breakes and cannot see much and im testing the wire from behind the front wheel to the sensor plug right ??
btw any idea if my clio 172 would be the same as its got no esp because i could just swap them over to do a quick test ??
From memory after market ones don't fit, genuine only I'm afraid, and you will be lucky to find second hand as they always break when being removed
Yep, I had 2 from GSF and 1 from a local motorfactors and all were wrong.
