Alternator cable snapped.
DaveDreads
I've found out what's wrong with the dog kennel, the alternator isn't charging the battery.
So I decided to take off the live wire and clean the connector,
in the process of undoing the bolt the connector snapped and the bolt now turns with the nut.
Is it new alternator time, and if it is, do I need a new aux belt kit,
or can I just swap the alternator with the existing belt and tensioner?
Also what do I do about the wire, can I just strip it and fit a new connector?
DaveDreads
I was trying to undo this nut and the connector snapped,
and the bolt turns with the nut, probably because they're so corroded they're now one piece of metal/rust.
Dr HMS Derv Destroyer
  MK1DCi/vivaro/REN’11
Right, soak the nut in wd40 for a few hours, stick a screw driver behind the nut ( flat head driver ) and pull the screw driver towards you as you undo the nut.
Depnding on how much cable you have left, you might be able to recrimp it.
Couls be a fudged alternator if its not that connector.
And personall i wouls put a new aux belt on as they cst penuts to buy
  Titanium 182
Fabricate a way to charge your battery from a wall socket and charge it while you're at work.
DaveDreads
Already sprayed it with WD40, there's just enough cable to recripm it.
Won't I need a complete aux kit if the belt comes off?
No, your aux tentioner should be fine. I would presume you'd only need the aux belt changing if you have the alternator off
  182/RS2/ Turbo/Mk1
Belt will be fine too realistically, despite what some on here will no doubt say the reality is that there is no harm in detensioning and retensioning it, its a spring loaded tensioner anyway in fact.
That said, if its not been changed for a couple of years anyway I'd take the opportunity and do it while you are there.
Alternator itself should be fixable, just take it to somewhere that specialises in them near you.
  Ph2 172
This happened to me at bedford, if you remove the black plastic guard on the back of the alternator.
There is a 17mm nut if you hold the 13mm with a spanner and tighten the 17mm it pulls the fitting tight against the back of the alternator
Allowing you to undo the nut in question.
Hope this helps
DaveDreads
Right, I cave-maned the f*cker of by hacksawing through the nut,
all I need to do now is get a new 13mm spade connector,
and a new 13mm flanged nut, unless it's some kind of weird special French nut?
Then I can jump start it and see if it's solved the charging issue.
you did try taking the nut off the proper way didnt you? cave man tools and tightened it up instead of undoing it ? :eek:
13mm nut with a copper washer behind will do IF you cant get a flanged nut anywhere.
DaveDreads
The whole lot span together, other than trying to dismantle the alternator in the engine bay,
there was no other way, i'll probably put it all back together and it'll still be f*cked.
You know what the dog kennel's like, it's not happy unless it takes all my money.
i would come round and do it for you but andys just got a porche come up thats ditched it into a lampost. thats me running around like a looney for this week.
get yourself the nut and a crimp spade connector ( altho im sure they're ring connectors ) and take your time doing it. you'll need a crimp tool unless you want to bodge and have a spark display going off !
Djw John
Scotland - South
Hope this helps
This
DaveDreads
I'm going to strip the wire back a bit and slide one of these over it, no idea if I need to crimp it in place or not though.
yeah, the yellow bit needs to be crimp't to to te cable. it acts as a crush clamp on the wire to hold it still. iv tried it with pliers before but it doesnt hold very well
hope it fecking fix's it after. made me laugh after all the effort to change the starter, first jump start and it fires up lol.
DaveDreads
I know I feel guilty and more than a little stupid that I didn't check the battery before you came round and changed the starter,
but at least you know how to change a 1*2s starter motor now. lol :eek:
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
Getting there aren't you Dave. You'll be back in love with it again soon I am sure.
DaveDreads
I'm not sure about that mate. lol
I've truly had enough of Clios as an everyday car.
I honestly think the French designed these cars to last 10 years,
because it's just one problem after another now, I had 5 years of relatively trouble free motoring,
those days are well and truly gone! :(
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
Ye Dave get some grips on them. Wrap some electrical tape round. Bodge it. The French bodged the cars when they built them didn't they ;)
Cringing at the thought of using pliers on crimps LOL
maybe its bad im an electrician :eek:
get a few crimps incase if you f**k one up! :p
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
Ye deffo get a few crimps, strip wire, twizzle it and fold over and stick into crimp. I'm sure you know that already though. But just in case :)
MarcB
  Vw Golf
This happened to mine, What i done was get the nut at the back of it to tighten it up.
Then got a large connector and crimped it with some solder inside and then red taped it up.
Got the Aux kit and starter done and then the garage (SWR) sprayed grease over it and it seems to be holding out well.
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
Inside the crimps too, the metal contacts go up inside plastic crimp part roughly half way, make sure the metal inside crimp does crimp onto the casing of the wire. Else connection may not work. Know what I mean?
DCI RAZ, help me out here. That's right isn't it?
  BMW 330ci sp/ 172Cup
I'm no electrician but make sure you buy a heavy enough duty ring terminal. Not sure what amps are drawn through the cable but you don't want a light weight crimp terminal on there.
Btw. Our terminal did the same and as a previous post says there are two nuts acting as lock nuts securing the ring terminal to the post.
MarcB
  Vw Golf
I used a heavy duty o-ring like this one below.
I would not be using some small thin one like this.
  Lionel Richie
common fault, the fix under warranty back in the day was to replace the entire engine bay loom instead of a £2 terminal, madness but that's Renault for you LOL
DaveDreads
So how the hell do I get at the locking nut behind the plastic casing then?
Because when it comes to reconnecting it, how do I stop the bolt from spinning when I tighten it up?
Yeah two crush fins inside the plastic casing. Strip the wire back and push it until the wire starts to come out the crimp. Dont crimp it on the wire casing or it'll melt it. Or make a bad connection :)
you want a big ring crimp. Bit of red heat shrink ( or any colour ) and srink the heat shrink onto the cable and the crushbit of the crimp after you have secured the wire. Or cover it in elec tape
DaveDreads
I don't know what the f*ck you're talking about lol.
I was just going to jam it on and crush f*ck out of it,
it honestly can't be that f*cking hard to mangle a connector onto a wire and make it work?
