100% complete 172RWD! - updated
Are you using the same brakes on the front as on the rear? This will cause locking up issues even though you have more weight in the back than most. I would replicate the V6 model if I were you.
Seems a bit over kill to have 4 pot rears then give then hardly any load? Surely standard fronts on the rear would be better value?
They also have the handbrake mech too!
Needs a valve to set it up etc .
engine is in rear but fuel,rads,battery,jack & tools,removable fuel tank 5L.
tyre foam,fire extinguisher ;-).
Will be finishing off some other bits this Sunday rready for it to be sent back
to k-tec for finishing off.
