Clio mk1 GTT 1.6 project
Car  clio mk1 & 206
This began when overheated the engine, i said well let bring some ponies wont be bad. the stock engine its a c3l with 74 cv din.
ive started looking and i found some bits of a breaking 11TURBO
thats how all began
before
when i started thinking all things that i needed never thought it will be so many!. Unfortunately in my country isnt easy to find due to crazy customs fees and taxes and laws to find all the things in time.
This proyect was many times delayed waiting parts
let's begin
Re: Clio mk1 GTT 1.6 proyect
gearbox reinforcement
R19 16s interior
new water pump, alternator refurb and many more
the original gearbox jb3 was short and couldt go further than 178 KMPH so i realized that some megane and kanoo has a larger fifth gear
i drove crazy adapting R5 gtt oil bleed pipe to this car, but i want something solid
an upgraded turbo cam
all the suspension and engine were disassembled, everything was check and all needed were changed
RSI rear axle with Xsara calipers on it
New front suspension, shocks and short springs now are stiffer and lower than factory
Subframe reinforced
then it was powdercoated
Now the engine
First a deep clean and VHT all around
Rally spec head
competition valve seats in beryllium copper and bronze valve guides in high quality
adding one of the needed gauges in order to take care of the engine
New chain, new tensiones and forged pistons.
Heat wrap, dural valve plates, and uprated spings
tomorrow guys i'll update the post with more photos.
not, its 1.6 from factory
[h=4]1.6 L (C2L y C3L)[/h]
  • Cilindrada: 1565 cc
  • Diámetro de los cilindros: 77 mm
  • Carrera del pistón: 84 mm
  • Número de cilindros: 4, en Línea
  • Válvulas: 2 por cilindro, en al culata (a la cabeza)
  • Potencia: 74CV (54,5 kW) a 5000 RPM (en C2L versión RE con carburador: 78 CV)
  • Par motor: 12,3 kgm (118 Nm) a 2750 RPM (en C2L versión RE: 12,5 kgm a 3500 RPM)
  • Ralentí (marcha lenta) 800 a 850 RPM
  • Relación de compresión: 9:1
  • % CO: 3 % Máximo
  • PPM HC: 600 Máximo
  • Alimentación: Carburador Weber 32 DRT (RN hasta 1994 y RE hasta 1998); Inyección electrónica Monopunto
  • Combustible: Nafta Especial Sin Plomo
  • Tanque de Combustible (Capacidad): 55 litros
  • Material del Block: Fundición de hierro
Good work mate, it looks like you know what you're doing! I wouldn't know where to start with something like this.
at the begining i didnt know what to do, but i found a crazy man wich is the president of renault 11 club of Argentina, who in his spare time likes to build this kind of engines. but iam special and i drove him mad with the head and the gearbox jajaj. without him, my brother, father and other people who helped me i wouldnt be possible
wili clutch
a long daw was it
this how it looks with the Dinard
last pictures
yersterday photo
now i need your help guys. this willi wings needs something like a plastic washer in the upper part with each bolt. i dont find the washer on ebay or local renault.
if someone could help me
i need the 77xxxx numer or if its selling in some web plese let me know
Hello,
I'm from Brazil and I also have a Renault Clio 1.6 8v 1996 engine c3l.
I'm looking for the exhaust manifold to put this turbo engine. As there was found, would make tubes.
I see you're using a cast collector in your engine. Which collector car is this? Help me a lot.
Another issue that need to be researched and attention on this engine and rockers. I found a picture here which has a holder for the tips. We manually aluminum.
http://lh4.ggpht.com/_iYS872z8NXU/SxF3xCui1NI/AAAAAAAABsQ/O-0uki4EtUc/s640/DSC03844.JPG
Which car is the support that is using?
thank you
Hello,
thank you
its easy to find in uk or france
http://www.ebay.co.uk/itm/EXHAUST-M...arts_Vehicles_CarParts_SM&hash=item3cd00f6461
remember to use the gearbox holder, otherwise this exhaust manifold will brake because of turbo weight
cheers
