Possible Rocker cover change PH2 > PH3
I currently have this -
Now is it possible the change it to look like this -
I have AC if that complicates anything, I'd want to do this with any loom modifications. Changing the loom connectors I can live with. I unsure if the ECU will be in the way as it's mounted at the back of the engine and I'm not sure if its connected to the rocker, head or block.
I just like the cleaner look and plus I have a PH3 afterall :)
Mat.
"should" be do-able but you will have to moddify the loom (TB, IAT and maybe coil)
Are these modifications changing of loom connectors and/or additional loom.
Will existing injectors and leads not foul considering the differently designed rocker?
I would have said no as throttle body is in the manifold.
My thinking is I'd use the throttle body from the other rocker, so a remove and replace.
Thanks for the replies.
