Clio 197 CUP Cambelt 2008 model
Car  2012 Astra & 197 CUP
HI
New member here. I have just purchased a 2008 CUP edition with 22k (with s/h,and mots to prove mileage) on the clock. I here that these cars require a cambelt @72k or 5 years. There is nothing in the paperwork to suggest that it has been done. Are these engines known for belt failures??? as with me only just getting it I could do with not spending more at the mo.
The ar I HAVE is a Racing blue model with the recaros and black speedlines + Air-con. It is immaculate and as new inside/out. I paid £6,100 for the car.
I have not had a Renault for years and I drive a Astra Vx-Line 2012 CDTi 2ltr 165, (DTUK tuned to 218 bhp) as my daily driver.
What are your thoughts guys on the cam-belt? and where is the cheapest best place to go for it?
thanks in advance..
£399 at Renault, well that's what we charge on Clio 197/200 and Megane 225/230. Thats for a cambelt kit and Aux belt kit, cam plugs etc.
Say what? I got quoted £900 for a cambelt service at my local Renault, and that was down from £1100. (I wouldn't/didn't go there, but I was curious of price).
you'll know this already but the waterpump should be changed too, why they don't build it into the price i don't know!
Why is the 197/200 a fair bit cheaper than the 172/182?
Simply because of the Aux belt set-up.
Ali your place do it wrong then as its not 399 for rs models.
On a 08 plate they changed it to 6yrs or 72k
Yea i know, the only reason we do them at that price is to get the work. I can do a 197 belt in nearly the same time as a 1.4/1.6. About 2 hours ish. 225 etc is abit longer.
Most of them we see are ok normally as we dont see anything over 40k. Did have a low miler once, around 20k and the water pump was like a Christmas tree.
Certainly get the belts changed.
Cheapest, Look for a local trader on here. Where are you located?
hi
I am located in south wales near Swansea. Right guys is it 6 years old on these 197 08 plates or 5 years?? to change the belts???? mine is an 08 plate like I said with22k on the clock.
If you look in your service book it shall tell you the interval. From 57/08 plate they changed the interval to 6 years 72k. Pm me your reg and I shall check for you in the morning.
