additional 12v supply
  172 FF and Fabia VRS
Hi All
i want to add an additional 12v supply in the boot.
is it easy enought to take the supply from the exisiting cig lighter and run it to the rear?
just a thought could i run more than one addional (one to rear seat and one to the boot?)
I took a supply from the cig lighter to under my dash for phone/sat nav
The extension works great but the cig lighter doesn't work if something is plugged into the extension
  16v 1.6 Clio MK3 GT
hmmm im curious because i was going to run a cig socket into the middle trim, by the rear window buttons, so people in the back of the motor can charge a phone as well lol. but if it will effect the front, hmmmm.
the additional 12v has turned up with 2 wires. Red and Black.
the feed in the car has 3? can anyone advise which 2 of 3 cables i need to get the feeds from?
electrics is not my strong point
  XC90, 330d, Trophy’s
I would imagine the third wire on the factory 12v socket would be for the illuminations.
just grab yourself a meter and test which is the live, earth and then switched live for the illumination and connect your red/black accordingly :)
i check it out - need my bro in law as i am colour blind to help lol
was hoping someone would say this is this that is that lol
That is right. I can't remember such colour wire is which though.
Why run a wire from the existing cigarette lighter? Just splice into the interior boot light wire.
When you shut the boot the lights goes off.
Checked tonight, the red/yellow is the main cable with the grey being the other. The blue wire is the lights
I tapped into the wires just before the cigarette lighter connector...
The red and yellow is positive and the grey/black ish one is negative. I didn't touch the blue one its for the light
