K20 powered 172
Chambers_RS
  Clio 172 Cup&Leon K1
Not throwing it in the hole stock 👌🏻
Pile of upgrades
Honda timing chain chain kit
550cc injectors
Alternator relocation kit and billet thermostat housing
New style PMS top mounts
Hybrid racing shifter and cables
Chambers_RS
Right and where is the turbo/supercharger?
Don't be a massive vagina, we all know you've got deep pockets😉😂
Haha not that deep and only plastic 🙄😂😂😂
I toyed with the idea of boost but thought it might take away the Clio personality 🙄😂😂😂 if that’s at all possible with a Honda engine 😂
Need my mounting kit now 😉
Crayola
I give it 3 trackdays tops before you announce which turbo you've gone for😂😂
Honestly Danny's sequential just makes gears look like blurs😂 Just thought I'd throw that in there for you too😉👀
Louis
I Park Like a C**t
Pile of upgrades
550cc injectors
The shifters you can get for these engine/gearboxes are sooo much nicer than the clio offering. Dont blame you for going this route and cant wait for the updates!
What's happening with the exhaust?
Chambers_RS
The shifters you can get for these engines are sooo much nicer than the clio offering. Dont blame you for going this route and cant wait for the updates!
Yeah defo! This hybrid shifter is proper smart.
Got a new manifold and link pipe coming but want a RamHorn exhaust manifold which I’ll sort once it’s in and working
Hxrry
so-wax.com
ClioSport Trader
Only just caught up on the thread! Serious bit of kit!!
I sold a car to Danny @ Custom Production who're manufacturing a kit for the k20 swaps, he was telling me about the progress they're making on the kits and it sounds very promising! Is that the kit you're going for too?
Chambers_RS
Yeah I’ve paid for Danny’s kit 👌🏻
Just need it now 😂
Chambers_RS
Spent some time on the Clio fitting some nee parts.
Started by getting my Laguna hubs built up. I’ve machined these to be able to produce much more camber and accept a large ball joint pin bolt.
Got a 20 tonne press to press the bearings in which worked really well.
The hubs needed the machine work to take advantage of the PMS suspension
Subframe was strengthened by PMS
And to finish the hubs off with some new brakes
Think I’ll have an issue with wheels fitting over them 🤦🏻‍♂️
Also got a new heated windscreen and the Honda gearbox is booked in for a plated diff to be fitted on the 15th.
scotiamr2t
  Mazda 2, Ph1 172
the PMS AP brake kit is epic, what wheels you trying to fit it under? I’m contemplating swapping to the laguna hubs aswel but undecided as yet
I’ve made my own tubular subframe and lower arms, waiting on my custom RC pins arriving before I can fit it all together
haimsey
  ph2 172
Judging by the effort so far, the result already speaks for itself
with regard wiring, you using standard Honda engine/Renault interior looms and trimming out the unused wires? Or going for a full custom loom?
Chambers_RS
The Kits really nice but designed around the Braid wheels that puremotorsport sell. Nick doesn’t think this kit will fit under TD 1.2s which I’ll need to address 😂
I’d be very interested in seeing the tubular subframe and arms if you don’t mind posting pic or PM them?
Chambers_RS
Thanks bud.
I was going full custom loom with DTA ecu on the ITB engine but not really sure on this yet.
The Honda KproV4 seems an incredibly easy option with it fitting the OE loom etc and seems a really good piece of kit.
Once the engine is in I’ll look more in to that.
scotiamr2t
  Mazda 2, Ph1 172
I’ll send over a few snaps of the subframe etc when I’m back at the garage midweek.
I hope the brakes fit under ultraleggeras as I’ve 2 sets still in boxes
Chambers_RS
Yeah please be good to see. I was thinking about going that route until this kit popped up.
Fingers crossed, if you send Nick a wheel he’ll trail fit it over the brakes before you buy
Twingo 1??
  Twingo 133 Cup,
If you want wheels with good clearance for big brakes td Pro rallys are good for space. I used to run alcon 4pots and 300mm discs with them on my rally puma. Most gravel rally wheels are designed to run with the biggest brakes you can under them.
Ps your mental! (in a good way)
RuskiWeldFab
  Clio 172, RS4 B7
View attachment 1509063View attachment 1509064
View attachment 1509066View attachment 1509065
Think I’ll have an issue with wheels fitting over them [emoji2359]
Also that design of wishbones is totally diffrent to mine. Is that not PMS I assume?
robzracing
This is AP news isn’t good. I’ve been ordering these from Nick this week although he’s out of stock of the discs at the moment.
I run both ultraleggeras and 1.2s so I really need these to fit.
I hope the 18mm spacers will help but I’d better speak to Nick first.
Chambers_RS
My 1.2s I tried in the pic above have 20mm spacers on and don’t clear
It’s more the barrel of the wheel than the spokes
