Monaco 172 Track Car
Krarl
With the 5 series out of action for a bit I had to make the Clio road (semi) legal again
I paid a mechanic to do all the hard work
MOT passed
It's made me miss how fast, smooth, refined, comfortable and effortless the 5 series is. I've driven it for 1 day and I feel ruined! f**k
Krarl
I have ruined this car for the road
I drove it for 2 hours yesterday and I wanted to kill myself afterwards. It's great if you're hammering it, but my knees and shins hurt when I need to be sedated with my pedal inputs. The coilovers fling me out of my uncomfortable fibreglass bucket seat that I'm now too fat for whenever I hit anything even slightly that resembles a bump in the road too
But in other news, one of the lads at work has started 3D printing a few bits and bobs, I didn't have all the colours to do this but he did so he printed it for me. Not bad for a 3D printer! It was a horrible picture to get right too but it converts an image into g-code/stl format so you can print it
That pic makes it look more green than it actually is
Louis
I Love Ed Sheeran
Should get it done as a lithograph
Krarl
Washer pump packed in and with all the salt in the road it made it sketchy driving. Constantly getting spray on the windscreen and can't see f**k all. Set about swapping the pump over today as I had the day off
The first step was stripping down the spare track car I had because I know the pump worked on that
After that I stripped mine down. Thankfully the wipers popped off nicely on both cars with a little puller and they weren't sized completely
Minging
Cleaned and removed my alarm
It's a good job I was in here, my wiper linkage was a gnats fart away from going Pete Tong
Little c clip was missing and causing the spindle to wear and drop with gravity and the weight of the wiper on there. Because the wiper linkage has a joint too it was knackering that took, so a good little find
More cleaning
Continued...
Krarl
I removed the alarm because it was installed by a f**king gypo c**t and it was more of a pain in the arse than something useful
It was so shoddily installed that they twisted and taped most of the wiring, and the alarm sounder wasnt even tightened down. It was finger tight and they used one of the heater matrix bolts, which is probably why I've had water ingress because it was loose as f**k 🤬
All the stupid twisted and taped alarm wiring removed and the bolt back in and tight
Fusebox tidier now
Wiper motor, linkage, bottle with new pump back in. Someone had replaced the pump with a Chinese knock-off which had failed, 22 year old genuine Renault pump in
Cleaned and coated the plastics
Gave all the joints a good coat of ACF
All back together. Engine bay given a quick clean.
I put the rubber seal back in at the back of the engine bay. I've never ran this but I've noticed whilst plodding on at 50/60mph on the motorway the blowers get a bit cooler. I think without all the excess s**t on the engine it doesn't work as hard and there's nothing blocking the rad either. A bit less 'through' airflow might help
Tested everything, wipers smoother than ever, I just needed to use a bit of stranded wire to clean out the washer jets
Krarl
Driving home, going about 40mph and hit something the size of a football
Out of nowhere, it made 2 massive bangs as it went underneath and my soul left my body via the arsehole. My sheer luck it smacked straight on the gear selector🙃🙃
Undertray fucked, selector arm bent (I think) and it won't go into reverse. Spent 2 hours laid on the floor freezing
f**king cars. Kill me
Everything's covered in salt too, my rack boot is split and the track rod has play in it now too so anything over 60mph and it vibrates the steering. Quite apt because everything else rattles and vibrates like f**k
hopgop1
That's some s**t luck, but at least it didn't send you off the road. Is the 535 close to ready at least?
Krarl
FFS! I want my Clio engine! x
I'd quite like to have 1 roadworthy car that doesn't grenade, but life's not geared that way🤣🙃
f**k that! What a c**t.
Can you do bangernomics for a month, I'm not sure the Clio is going to survive another brick.
f**k knows, I might have to at this rate
If I can't fix the Clio this weekend I probably will just buy something for less than a grand and drive it like a complete c**t for a few months
