Mondial 172 Cup OEM+ / Rolling Resto
MAXRUNDOWN
Miserable day today so I've took the opportunity to restore the headlights, I'd machine polished them when I got the car but it never lasts, the only way to keep them nice is to clear them..
Scruffy yellow lights
Cleaned and flatted off, masked up with a soft edge around the lens, set up in my professional spray booth.
After a few coats of 2k clear, there's a couple of bits of dust in it that'll flat and polish out tomorrow, but that's a massive improvement over the before.
While I've got the equipment to spray properly, I couldn't be bothered sheeting off the garage to protect against overspray, or cleaning the gun afterwards so I used a can of ProXL 2k in a can. I've not used these before, it's expensive Vs 'proper' 2k paint you put through a gun (£18 for a 200ml can, Vs around £30 for a 1.5L kit of 2k clear) but it was definitely worth it for the ease of use.
MAXRUNDOWN
Had a few hours outside today, exhaust is fitted, brakes bled, PAS fluid filled up, got the inlet manifold fitted, ECU which has been off to EFI parts for a base map. Fitted the battery ready to turn it over and the battery is dead 🙄
It's sat on the trickle charger now doing a reconditioning cycle, my booster pack is in the mrs' car so I'll give that a go when she's back from work..
MAXRUNDOWN
It's running!
Phone mic makes it sound like it's whirring really loud but it's not.. there's a little weep from the banjo on that PAS pump, and a tiny weep from the bleed screw on the thermostat housing but other than that it seems fine, I've ran it up to temperature and shut it off, I've got a busy weekend of running the kid around to clubs, a birthday party etc so not sure if I'll get chance to touch it again before next weekend.
Next opportunity I get ill drop the oil and put some Millers running in oil in it, the gear linkage needs setting up, airbox needs to be fitted etc but it's nearly ready to go back on it's wheels.
MOT before Xmas hopefully 🤞
MAXRUNDOWN
Got up early this morning to get the oil changed before we go out, caught the first couple of litres of drained oil in a clean clear measuring jug to get a good look at it for any nasties, nothing to report, I've kept the oil filter which I may cut open later.
Fitted a new copper washer to the coolant bleed screw too..
Brigsy
  T.Turbo
Good stuff the millers running in oil. Not sure if you have used it before or not, but change it often and keep the load light, as its piss thin.
MAXRUNDOWN
I've not used it before, I'll probably change it again after 100-150 miles, then again at 500.
npt
  BMW 320d- 172 cup
Leave the oil for 300miles, then just stick in normal stuff and send it, be fine
MAXRUNDOWN
Nearly there now, gear linkage connected and set up. Under tray and arch liners fitted, Wheel alignment done with some toe plates, it won't be perfect but it'll be good enough to get it MOT'd and driven to get it done properly.
I need to get the rear discs and pads changed, torque the driveshaft nuts, fit the airbox when some new Flexi ducting turns up for the cold air feed and fit a new front splitter then book an MOT.
Matt Cup
  Iceberg 172 Cup
If you haven’t got a cup splitter oreca store still sell them.
MAXRUNDOWN
Yeah I've seen them, I definitely want a proper cup splitter but for now I've just ordered another Skoda one
Yarp
  182 Turbo, E46 M3
I looked at them for mine but the postage cost is mental. It comes in at about 140 euros.
Although when I looked, it didn’t increase with quantity so I’d be happy to join in a little half arsed group buy with them, even if all it did was split the postage 2 or 3 ways. I’m far too tight to pay £110 on post. I could fly there and pick it up myself for less than that.
MAXRUNDOWN
Got a few bits done this weekend, airbox is fitted with new Flexi hose for the cold air feeds, Skoda front splitter fitted and front bumper fitted properly
Got the back brakes done today.. new brembo discs, powder coated pad holders, I stripped and plated the mounting bolts and retaining clips/pin.
Got the caliper sliders cleaned and greased and rear calipers bled.
Ended up working in the dark by head torch which was sub optimal but it's back on the ground now
I'll refurb the calipers when the rear beam comes off for the rear end refresh (probably next winter) and bin the scruffy brake pipes for the full braided kit I've got in the spares box.
That's it 'done' for now though, pre Xmas MOT not going to happen now as I'm back at work next week, but I'll get it done early in the new year
aldo_87
  Campus 1*2
Aye, I took it down to CSF 24. It's sat in the garage for most of 2025 though, conduring ways to show me its EML! I still kinda keep in touch with Pete, usually moaning about him not using his 635 CSi enough! 😄
MAXRUNDOWN
Haven't touched this since before Xmas, I've just exchanged contracts on a new house so under a bit of pressure to get it sorted now so I pulled my finger out yesterday and got it off the axle stands and gave it a run down the street, all seems well which is nice.
MAXRUNDOWN
Well that's mildly disappointing but not the end of the world.
Ive ordered a new 3rd brake light but for the re-test I'm just going to put some black electrical tape over it then it can't be tested
Ordered a new number plate light, I looked at the current one (was brand new from Renault just after I bought the car, and one of the pins is loose in the housing so it doesn't push into the wiring plug on the loom)
I've adjusted the headlight to match the other one with the car against the garage door.
And the power steering leak was on one of the AN fittings on the advocult HP line where the pressure sensor is, I've flogged it up and cleaned the mess off the front of the block, and topped the reservoir up with about 200ml of fluid.
Retest booked for Friday morning 🤞
MAXRUNDOWN
Happy with that, alignment sorted too.
I've just had it on temporary day insurance for the MOT, need to sort out a proper policy with some kind of agreed value etc, I wouldn't want something to happen and an insurer trying to pay out £3k for it now.
I'll tax it on the first of march and start getting some running in miles on it, aiming to get it mapped probably in May
Polynesian
  Alpina B3, 172, 325i
Nice one! Had my MX5 mot’d today- no advisories! That’s an achievement. The underside was all dinitrol treated and I was able to give it a careful look over- it was very well done and looks properly protected. One less thing to worry about!
Get that car on a proper policy, and on a fun road!
MAXRUNDOWN
I'd love another MX5, I had a lovely neo green eunos V-spec about 15, yrs ago. Would have another V-spec, S-spec or RS limited in a heartbeat
MAXRUNDOWN
Got my new steering wheel fitted today
Feels so much nicer than the OEM wheel, and matches the interior really well.
And fitted a new 3rd brake light from Barthel auto solutions
There was actually some sight of the sun in the sky today, roll on 1st of march when I can start using it.
MAXRUNDOWN
First 50 miles done today without any snags, taking it easy just varying revs/load and engine braking. Feels good to be out in it again. Remember how horrible the seating position is though, I'll have to do something about that this summer
Looked good from the window of the gym this morning
MAXRUNDOWN
250 miles done now, worked from home this morning so got the oil changed after lunch
It could have waited a few more miles, but I'm confident the rings have had time to bed in and I'm moving house in a couple of weeks and would rather any oil drips went on this drive rather than the new one.
I picked up a used set of GAZ rear shocks, and sent them off to GAZ for a service, they've worked out free once I moved on the other bits that came with them which is a bonus. I'll probably pick up some koni adjustables for the front to go with them too.
I've also bought some PMS stub axle spacers and 1° camber shims so I'll fit them all in one go once the move is out of the way.
Got a fire extinguisher to go under the passenger seat, not a particularly sexy mod but sensible to have one in an old car.
Mapping is booked at EFI on 8th of April, then assuming that all goes well I'll be concentrating on CSF prep, I'm going to fit an oil cooler, and I'd like to get a set of 15" wheels (2118's or evocorse x3ma) and decent tyres too.
