Axle stands
charltjr
I’m still using a pair of very cheap Halfords axle stands from about 20 years ago.
They do the job, but they’re a bit crap, no rubber pads, quite a low weight rating, not exactly confidence inspiring when you’re under the car, etc.
I’ve been toying with the idea of a kwik-lift or similar but FML they’re expensive.
Any recommendations for decent axle stands?
Short Norman
  997 C4S
I’ve just given some rusty old ones to the scrap man that were about 30 years old. They’ve been replaced with some nice new orange Halfords 2T ones.
charltjr
I’ll stop complaining about my manky old Halfords 2t jack stands then 😂
This is my 2t Halfords setup. Still always extremely paranoid lifting the car up and putting on stands. Once there, i'm all good no probs, just the journey scares the crap out of me!
McGherkin
McPension
Halfords cheapy ones and don’t be such a baby/drive a car heavy enough to immediately crush you to death when if it falls off the stands to minimise the suffering.
If you ever need to go really high up with them, do it in stages if it looks sketchy.
I actually thought sod that and borrowed the scissor jack from my neighbors Citroën Dispatch, had so much more confidence woth the scissor jack than mine.
Dicky Belly 3
Scissor Jack's are made out of the cheapest materials and an accessory with a car for roadside emergencies. I have seen loads of them snapping when used multiple times.
Thinking that they're safer than a conventional thick and sturdy jack is proper daft behaviour.
Mainly because in order to get the height then it drags the car to you and thus moves it which is scary.
The Dispatch one has a really big footing and is suitible for lifting a van full of tools which is prob best part of 2 tonnes and my clio is just over 1 so should be good.
Ultimately I feel more confident because it raises vertically rather than up and across.
It also fits the rails better or the squashed rail because of the top is better than the Clio one
I'm not keen on the normal ones, but the ones for Vans are much bigger than those for cars
Ant1
Brembo! Brembo! Brembo!
I use these. Price is good, rubber pad so rails don’t get damaged and rock solid.
£46 delivered with code.
I have three sets of Halffords advance stands, won’t use them now.
As for the jack i have a sealey low and halfords advance low 3 tonners.
Mr Trailer Man
Flat pads on them look pretty good actually
MLB
Thanks for the link, I was just wondering about these the other day when I was reading your Porsche thread and did think they looked good.
£86 delivered for two pairs👌
TheBandit
  Monaco172, Green1.2
Do you leave the handbrake on? Car shouldn't shift while lifting, jack should roll towards the car to compensate for any movement
Mertin
  Ph1 172&Ph2 172 Cup
Iv got both sets of halfords, the orange 2T ones and also some black ones with the 'ratchet' function.
Much prefer the pad on the orange ones and sits fine on the clio chassis rails. Apart from my integra dc2 that had front and rear central jack points, the clio is one of the best. Plenty space to get onto the lower arm brace and still leaves the chassis rail free to get an axle stand on. Some cars nowadays have very little decent, stable points below for an axle stand. Plenty points for a flat pad on a lift but not so much the 'U' of an axle stand
