Have you the part number still please?.also what is the part calledI got a new one from renault a few years back, might still be available.
7700420954 is what I have written down here for it. I could never find one in Aus so just folded up a piece of out of some alloy sheetHave you the part number still please?.also what is the part called
Great thank you7700420954 is what I have written down here for it. I could never find one in Aus so just folded up a piece of out of some alloy sheet
Bc's are s**t for road use sadly. The adjusters dont do much, its either soft or hard. Cooksport showed me one on a damper dyno and the rebound done nothing for a few clicks. I actually hated the set of bc's i put on my old 250 cup.
I also rate the bilstein b14 for road use. Plenty firm enough, nowt to adjust. Stick them on and forget.
I'm having the same issue with mine atm. Currently 10 clicks from soft all around as I was hoping it would help with the bumpy roads near work but it feels s**t. I'm beginning to think I should have just bought bilsteins instead as they were great on my 182. I'm debating swapping or sending it somewhere decent for a proper set up.
Yep i cant fault the last set of B14s i had,why did i go for BC this time 😆Bc's are s**t for road use sadly. The adjusters dont do much, its either soft or hard. Cooksport showed me one on a damper dyno and the rebound done nothing for a few clicks. I actually hated the set of bc's i put on my old 250 cup.
I cant say i cant tell any difference driving with the 2118s and when i had my lightweight evo wheels.I think only counts if its a proper track/race car.Genuinely think those wheels are the best looking option for the Clio. Shame about the weight. I think if a set popped up with road tyres in a few months I'd be hard pressed to say no.
Looks great.
Ive bled calipers using a mityvac and large syringe before but never a pump trigger. Hook up the eezibleed, they work great and easy 1 person bleed.
Thanks for the recommendations on the bleeding tool.
What about on the solid engine mounts?,ok for road use or just stick with oem with the poly insert?
