Titanium MrBlonde
Have you the part number still please?.also what is the part called
7700420954 is what I have written down here for it. I could never find one in Aus so just folded up a piece of out of some alloy sheet
Any advice on setting the damper settings on BC coilovers please?.going to go out for an early drive tomorrow and have a play with trying to set them up for road use.
I have been reading up on some suspension set up companies which say for FWD is to have the front soft/med with the rear more firm than the front?.But then others say have the rear more soft?.this is to give the front more grip
Do you think its also best to start from the bottom setting of soft then go up 3/4 clicks each time until you find whats best for you or start half setting which is 15 clicks front and rear then go from there.
"For fast road use, moderately soft to medium front damper settings are generally better than full hard. While stiff dampers improve steering response, "fast road" driving requires the suspension to absorb bumps, potholes, and changing surfaces to keep the tires in contact with the ground for maximum grip."
For a road car I'd have it a little soft on the rear and medium on the front, these cars are not heavy enough imo when firm, makes them bounce about when they hit bumps etc.
I've got bilstein b14 and they are a little soft, but to me it works fine on road, little soft for the track though on the front, many coilovers are horrendous at dealing with uk roads.
Yeah B14 are well suited just for road use.Hard to find a bit of road where theres no pot holes or a car doing 30 😆
Just trial and error,have to just keep playing about till it suits my driving style
I'm having the same issue with mine atm. Currently 10 clicks from soft all around as I was hoping it would help with the bumpy roads near work but it feels s**t. I'm beginning to think I should have just bought bilsteins instead as they were great on my 182. I'm debating swapping or sending it somewhere decent for a proper set up.
The main thing with coilovers with a threaded bottom bracket is getting them set up properly. 90% of people use the bottom bracket to set the ride height which is the wrong way to do it.
That's a quick explanation of how to do it right.. once you've got the damper stroke set up properly and the ride height where you want it then start playing with the click adjusters
Bc's are s**t for road use sadly. The adjusters dont do much, its either soft or hard. Cooksport showed me one on a damper dyno and the rebound done nothing for a few clicks. I actually hated the set of bc's i put on my old 250 cup.
I also rate the bilstein b14 for road use. Plenty firm enough, nowt to adjust. Stick them on and forget.
I've had clients that are BC Racing authorised dealers, and they consistently tell people to avoid BCs lol. The only people I've seen having positive experiences from my time with Hondas are the people who are having custom BC-supplied stuff sent to them as a sponsorship, not their off-the-shelf stuff.
The BC in BC Racing stands for Bad Choice :P
Thats what i will do once i have the refurb beam on,i will get Alex to do alignment and corner weigh it.Then if still not great back to the B14s,i think just went with BC as they have a great choice with changing springs,parts etc.But then i like the B14s and put on and forget.
Yep i cant fault the last set of B14s i had,why did i go for BC this time 😆
Only thing is having to pay out for a new set of B14s before i sell the BCs.Also i think having solid top mounts dont help on a road car.With the BCs you have to spend about £150 to convert them back to normal top mount set up,where as the B14s you dont,you can easily just swap back and fourth.
Yeah solid top mounts will defo add to nvh. I run oem top mounts on my bilsteins as i didnt want to drill the strut top. Quite good on oem too no complaints.
Also keeping the ride height at a sensible level is the way to go on a road car with all the variations in road surfaces/camber/holes, lowered cars pull you all over the road when pushing on from my experience.
Genuinely think those wheels are the best looking option for the Clio. Shame about the weight. I think if a set popped up with road tyres in a few months I'd be hard pressed to say no.
I cant say i cant tell any difference driving with the 2118s and when i had my lightweight evo wheels.I think only counts if its a proper track/race car.
With my PBS front pads kicking out way to much brake dust,even just on normal driving around,also having normal pads on the rear.With reading up on a lot of people rating the TRW brake pads,i bought Front and rears to change over on the clio.This should bring a lot less dust on the front wheels and better braking for road use.Also a lot cheaper than nearly spending £300 for performance pads which are just going to be used on the road.Also think the TRW pads will give me a much better brake balance,than what i currently have PBS prorace Front and brembo on the rears,thinking now i should of bought the Protrack pads instead at the time.
I normally just go easy on the brakes for 100 miles or so and check fluid levels.but reading so do firm brake from 40 to mph a few times,then from 50.
TRW pads all fitted and done a few miles to bed them in,but needs more and a brake bleed.Anyone had ago at bleeding the brakes with using a trigger from a spray bottle?.thinking to give that ago rather than ezi bleed or someone in the car pumping the brake pedal.
Next thing up is changing the engine mounts,i already have the poly dog bone but looking to fit solid top mounts also,worth doing on just a road car or just get febi oe mounts and the poly insert?.
Looks great.
Ive bled calipers using a mityvac and large syringe before but never a pump trigger. Hook up the eezibleed, they work great and easy 1 person bleed.
Thanks for the recommendations on the bleeding tool.
What about on the solid engine mounts?,ok for road use or just stick with oem with the poly insert?
Can’t help on that one. But I did discover my mounts are floppy and totally fucked when I was painting them the other day. I’ll let you find that out and I’ll learn from your mistakes (or maybe even success!)
