1.2 brake disc sizes??
Da
Car  Less
on a 2002 1.2 Clio, can someone quickly please confirm, are the discs 238mm or 259mm?? I'm hearing both and getting very confused! lol! ;) Any other details would be appreciated also :)
Is this spec corect;
Diameter 238mm Bore 61mm Height 41mm Thickness 12mm Mounting Holes 4
when i had a look at your car they were deffo 259mm
get some brembo max disks and renault pads from GSF
yeah cheers jon, fairly confident now ;)
Where would i get brembo's from? and GSF? :S
ps, how was the check? :approve:
Just use Any normal disks I use Halfords with the normal and the DS2500 pads.
The Halfords pads are very good FDB 845 I think and at £17 a bargin.
sorry daz not heard from my friend yet....
Brembos disks would look good on your car i know you like it looking good, federo (sp) normal pads run at a tenner trade or bendix from GSF are £12ish the disks are £30 each.
Halfords .... yes but i make a point of never shopping there ever!
ok cool, cheers jon. Do these look right as it doesn't say a size! :S Pads are fine at mo as only changed 4/5 months ago...just discs starting to corrode.
Some DO have the 238mm discs !!
Best way to see what yours is to quickly measure it up to be safe.
There are plenty out there with 238mm but mostly 259mm
Daz_2427 said:
lol! :S 238mm does seem to come up far too often for the 1.2's ;)
Nope Mk2 2 all CLio eacpet the V6 and 172etc run 259mm disks. They use the R5GTT and WIlliams and 1.8 16V pads. The R5GTT however used 239mm disks. the WIlliams and 1.8 and Mk2 2 none RS Clios uses the 259mm disks.
ive seen Phase 1 and phase 2 1.2 8v's with 239mm solid disks i was supprised to see daz's car with 259mm but it DEFFO does have 259 vented disks and the same lucas calipers as my old 1.2 16v
yep cheers guys, checked it out today. Jon is correct :approve: 259mm vented discs with Lucas calipers. Got my new ones, just gotta get them fitted now!
