my car is due its MOT so i have got to sort out a few probs,
the reserve fuel pump bracket has broke and needs to be replaced. the problem is i cant undo the bolts holding the remainder of the old one on, due to them rusting. i have used plus gas but to no avail, if i apply anymore pressure to the bolts to undo them the other bracket connected to the tank is going to break.
now this other bracket connected to the tank looks as if it has been bonded on by melting the tank and bracket together.
i would ideally like to replace both brackets if possible and start a fresh, however can the bracket attached to the tank be replaced??
http://www.btinternet.com/~weightspalace/auxfuelpump.jpg
