172 air delete,plastic pulley ?
Car  phase 1 172
on doing the aircon delete as prr the guide on here but i ordered the pulley before reading the guide so guessed which of the 2 timing pulleys from the saab 95 i needed
i ordered the far left and by the looks of the guide i needed the centre guide pulley
when mine came its platic and to be honest im not kean on it
is this pulley wrong and safe to use if i can find a belt (on the saab diagram this looks slightly smaller)
I put the ebay link up for the pulley I used although plastic it seems to work fine, plus I couldn't find any other pulleys with the correct hole size and diameter
might just ro order with the right pary number unless some can confirm f im.measuring the the where the belt sits only and not around the shoulder when cheacjin diamater
if im measuring right (belts path only) i have the same size pulley as per the guide Just from a differemt point in the timing side of the saab 95
