172 braking problem (any ideas?)
  • Thread starter Thread starter cliosportheth
  • Start date Start date
  • Tags Tags
    172
C
cliosportheth
im having problems with my brakes on my 2003 172,the problem is that when i brake coming up to junctions then the abs kicks in gently,at any other speeds then its no problem,i was told that it were the abs rings attached onto the end of the driveshafts that the abs sensors aint picking up the signals due the worn teeth on these rings,is what ive been told correct?
if ya have any ideas then il check them out too.
:dapprove:
As a matter of interest, is it all junctions, or just one or two you drive through regularly ?
