172 Cup Bearing
Car  172 Cup
I've recently bought discs pads and bearings for a 172 cup.
I got the bearings pressed in by a local garage however upon fitting the new discs and bearings I have noticed the bearings are the wrong size. I've checked the code on the original bearing to my new one and there different.
I've measured the diameter of the original bearing and its 25mm however my new bearing is 30mm. I've checked with GSF car parts and there bearings are also 30mm diameter and therefore incorrect.
Has anyone else had this issue going to try ring renault now for a resolution.
